On a vf-39, does the hole in the oil inlet bolt have to match up with the hole in the oil inlet line? Or is there a specific torque spec I should be going for? Thanks a lot.
They don't have to line up. The oil inlet opening is wider than the shaft of the banjo bolt to allow for circulation. As for tightening, use factory torque specs.
