Turbo Oil Supply Mesh clogging?
Discussion in 'Modifications & DIY how-to' started by monk, Mar 13, 2008.
  1. monk
    Feb 1, 2005
    2,074
    0
    just read the TSB on STIS... anyone have this happen yet?
    Will, have you seen this on the 07s?
    TSB's should be checked and fixed free of charge shouldn't they (if under warranty)?
  2. integroid
    Supporting Member
    Dec 28, 2004
    3,084
    0
    I removed the screen in my LGT per Jerry @ deadbolt's recommendation.
  3. Sparta
    May 2, 2007
    3,693
    12
    I think Will mentioned in another post that it shouldn't clog unless mistreated and that would result in not being fixed for free.
    Now if you sump tube happens to break and clogs it, you can probably get it fixed but clogged mesh would be the least of your worries
