Turbo Timer/Boost Gauge Install Space
Discussion in 'Modifications & DIY how-to' started by RamblinWRX, Aug 12, 2005.
  1. RamblinWRX
    RamblinWRX Member
    Next week i'm buying a Blitz DTT DCII (turbo timer with built in Boost Gauge) http://www.jdmautogames.com/product_3896_13258.html
    The LCD display is seperated from the display and is very small. I was wondering where is a good spot to put it on or near my gauge pod so i can fully use it as a boost gauge yet still get to all the ignition wires, i was thinking on the top part of the A frame right under the speedometer on my 05'. Is that a reachable spot?
  2. RamblinWRX
    RamblinWRX Member
    i meant the tachometer
  3. slpymnky
    slpymnky Member
    I've seen a lot of cars with similar guages mounted to the left of the cupholder. (on the little silver piece)
  4. Genya
    Yup I would use the cupholder space slpy mentioned.
  5. RamblinWRX
    RamblinWRX Member
    05' interior doesn't have that cupholder anymore, it has two cupholders by the e-brake, therefore no space there. I figured since the thing is the size of a pack of gum i can just stick it onto the gauge cover.
