Turning slotted rotors ?
Discussion in 'Modifications & DIY how-to' started by RUTSPEED, May 2, 2007.
  1. RUTSPEED
    RUTSPEED Member
    I had some super aggressive pads, I think some form of Hawk's on my STi...well I swapped them with a new set of EBC green's and I still have some squeling....
    I think my rotors, which I believe are power slot, are perhaps a little glazed over... can I have my mechanic turn them or can you not turn slotted rotors ?
    Thanks for the help.... Rut
  2. yerrow
    yerrow Active Member
    nope
  3. Trey
    Trey Active Member
    Actually you can, the tech just needs to be cautious as to how much the cutter bites into the rotor. I've had a set done before on the Civic. It was a Mercedes dealership my friend used to work at.
  4. AXLEJOHNSON
    AXLEJOHNSON Member
    I don't know anything about rotors, but could you lightly sand them to get the glaze off?
  5. WJM
    i can turn any rotor you want.
    If someone says that you cannot turn slotted and/or cross drilled rotors...they are being lazy. Its no different than turning solids.
  6. baddriver
    baddriver Active Member
    That's a good question, Thanks for the thread.
  7. Trey
    Trey Active Member
    No thanks for me? Screw you fags. :D
  8. sol drums
    sol drums Active Member
    there you go trey :bigthumb:
  9. Trey
    Trey Active Member
    You complete me. :p
  10. pEd
    There's another one Trey. Gotta rep for the 04's....
  11. Trey
    Trey Active Member
    :bigthumb:
  12. Alex
    :werd:
  13. crashtke
    Ok not to jack the thread, but I am, lol. I had some new rotors (brembo slotted) and pads put on the rear of my lil wrx due to a bad squeeling that only seems to happen when it starts getting hot from highway speeds or long periods of driving. It has not even been 4k miles and it has started again. Weird part is it is not when I am ON the brakes, but when they are not even pressed down. Hitting the brakes stops the squeel and then it starts again when I am back off of them. Anyone have any ideas?
  14. crashtke
    Anyone?
  15. goixiz
    goixiz Active Member
    is there an alternate way other than turning on a lathe ?
    I was thinking maybe a fixture on a grinding wheel (not the kind you can buy at sears). I have a precision grinding table (magnetic) at work that hold tolerance within 0.0005
  16. WJM
    Dude, a lathe is best. Like I have said...I have had ZERO problem turning anything from solids to slotted/drilled and slotted WITH drilled.
