Uppipe!?!?!?!?!
Discussion in 'Modifications & DIY how-to' started by mlh300zx, Nov 7, 2006.
  1. mlh300zx
    mlh300zx Member
    Mar 11, 2006
    27
    0
    Ok guys I have a question. I'm about to hit the end of my warrenty and feel it is time for a dp/up. i already have the catback exhaust. One option I was looking at was the helix combo. buy. Im trying to keep one cat so im going for the catted dp, but my question is about the up. Iv been reading around, but want some more opinions. Iv read that the flex will eventually leak and that the rigid could leak from the beginning.
    Would you guys go with the flex or no flex up pipe????
    Thanks.
  2. clemsonscooby
    clemsonscooby Active Member
    Dec 13, 2005
    1,536
    0
    Honestly, both are great and work well. The cases that you have read on forums are rare. Nobody can tell you if they were even installed properly or not. Also, it matters how the energy is being transferred to the uppipe or what application they were using the uppipe in (i.e. track, autox, or daily driving). If you are making a track car, almost all parts will break eventually. I use a solid HKS uppipe with no problems. I've installed it about 30k miles ago, or 2 years. Just buy whatever you can get a better deal on.
    or better yet... buy a gutted uppipe and save yourself a whole hell of a lot of money for the same pipe. I have a stocker that you could gut...:naughty:
  3. miloman
    Feb 3, 2004
    12,774
    1
  4. Deke
    Deke Active Member
    Jan 28, 2006
    2,694
    0
    Alex will definitely chime in soon attempting to sell you one of his gutted up-pipes. :)
  5. miloman
    Feb 3, 2004
    12,774
    1
    :rofl::rofl:
  6. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    0
    I had a turboXS flex-uppipe for about 40k miles with no leaks or other issues.
  7. SkullWRX
    SkullWRX Member
    Aug 17, 2004
    591
    0
    got a solid pipe (Crucial Racing Systems). Only leak I've ever had was from not tightening the bolts enough. Lock washers fixed that, no problems since. Solid theoretically give you a better flow, but without LOTS of power it won't make any difference. If you're looking at thermal coating, remember that you can't thermally coat a flex joint because it will crack. If you thermally wrap, the choice is yours. Regardless of what you pick, make sure it's 321 stainless rather than 304 stainless or cast iron. 321 will help you retain more heat and has better thermal resistance.
  8. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    Why waste your money on some fooey aftermarket piece when you can enjoy the prowess of a modified stock pipe? It retains that "stock" look whilst providing you with all the benefits of catless freedom. If you're interested in a gutted UP, please PM me :wavey:
    :fawk:
