Vacuum Line Boost Gauge Need Help
Discussion in 'Modifications & DIY how-to' started by clemsonscooby, Jan 15, 2006.
  1. clemsonscooby
    clemsonscooby Active Member
    If anyone has a boost gauge installed in their car, could you help me out? I need either a really good description of where to 't' the line into for the boost gauge. I am not sure if it should come from the cdv valve or the intake manifold. If someone has a picture they could take and send me or know where one is on the internet I would really appreciate it. Thanks for the help.
  2. moose
    Here's where I tapped mine. I actually got a 2" or so piece of vacuum tubing and a T so didn't cut anything.
  3. clemsonscooby
    I appreciate it, thanks.
  4. clemsonscooby
    moose, how about getting the line through the fire wall. Did you use the spot that kind of goes over the fender well where the fuse box is in the engine compartment?
  5. moose
    If you look above the clutch pedal from inside the car (you may need to pull back the carpet a tad) there's a rubber plug there that leads into the engine compartment. Just pull it out and cut a slot in it to pull the line through.
  6. clemsonscooby
    Is it easy to access through the engine compartment or does anything need to come out like the washer fluid bottle?
  7. moose
    It's easiest to get to from below... I'd recommend removing the plug from inside and shoving a stick or something through so you can spot it though; it kind of sits right above the frame so you won't see it easily.
  8. clemsonscooby
    so jack the car up then? so that i can get it through underneath?
  9. moose
    Or drive up on ramps... if you do jack it up, please make sure you use stands.
  10. clemsonscooby
    Always jack stands. Thanks for the big help. Now its just a matter of getting it wired to the clock radio power source. Is there an easier 12v source that i dont have to dig up through the dash for?
  11. moose
    Probably could use something off the fuse box. I threw on an add-a-circuit thing for switched power that doesn't cut out when cranking (my gauges are electric so had to have this). But the rest I tapped the clock pod for since I was using the autometer bezel and it was easy to get to.
  12. clemsonscooby
    Well I pulled down the carpet below the clutch petal. There was this white plastic thing that I unscrewed. Around the screw though, it feels like hard plastic. Is this what you drilled into, or how did you make the whole through there? Or am I doing this in the wrong place?
  13. moose
    Above the clutch pedal. It's a rubber stopper piece.
  14. clemsonscooby
    Well its installed, but I still don't have the power source yet and it works great. I can't figure out how to remove the clock. Is there some clips that has to be accessed from under the dash or can I just kind of pull the clock out from the top?
  15. moose
    You can pull it out from above with some effort. I used a flat, thin blade and slid it down the edge near the back and wrestled it out it that way. Be careful not to put a nick/dent in your dash though.
    Glad you got it working.
  16. wrxin8or
    Sorry I didnt see this until today, otherwise I could have helped you out with the install. Glad you got it all working
  17. clemsonscooby
    Well I am still working on the clock, but its minor. I should have the gauge powered up for night mode by tonight.
  18. clemsonscooby
    Thanks though.
  19. rexrocker
    The factory boost gauge draws power from a cluster behind the radio. I tapped power for my Omori from there. It is just a few screws and the radio pops out. Let me know if you need more detail. Good luck!
  20. clemsonscooby
    I finally got the clock out of the car. I am having trouble deciding which wire to cut. On the back of the clock there are some three letter abbreviations, but I not 100% sure of which I need to tap into. The options from top to bottom are BAT, GND, LIG, ACC. I figure the GND is the ground and I shouldn't tap into that. Can someone please help...
  21. moose
    I PM'd you, but it sounds like you want to tap LIG if you're looking for a light source for the gauge.
    BAT should be constant on
    ACC should be on with the ignition
    LIG should be on with the gauge lights and head lights
    GND is ground
  22. clemsonscooby
    Thanks for the help. I learned the hard way that the BAT is the constant on. I will connect into the LIG tomorrow monring, but for tonight the battery is just disconnected.
