Vf22
Discussion in 'Modifications & DIY how-to' started by jayjaysti, May 29, 2008.
  1. jayjaysti
    jayjaysti Member
    whats the stock boost on a VF22
  2. Weapon
    whatever you have it tuned for :) . I had mine tuned for 19lbs. I am sure you could get 22-25lbs out of it but it would be pushing the limits of this turbo. If you have an sti I would not recommend this turbo at all. Get something bigger like an 18G or 20G.
    Here is a compilation I put together a while back about all the IHI turbos if you wanted to thumb through em. Again none of them are ideal to go to from a vf39 IMO.
    http://www.wrxatlanta.com/forums/showthread.php?t=12330
    Hope this helps
  3. Cool_____
    Even an 18g is pushing it on a 2.5L. It just runs out of breath after 5500 rpms and falls on it's face. 20g is the minimum I would go with a 2.5L (whether it's a WRX, LGT, Baja, Forester, or STi).
