vf39
Discussion in 'Modifications & DIY how-to' started by josh booth, Aug 9, 2006.
  1. josh booth
    josh booth Active Member
    Where can i find a vf39?
    Already have a sti top mount on my 03 now need a bigger turbo.
  2. nsvwrx
    nsvwrx Active Member
    going witha bigger turbo you will also need injectors and a new fuel pump + tuning
  3. josh booth
    Buying one piece at a time.
  4. calmnothing
    a lot of sti guys here have upgraded to bigger turbos so you can try posting in the wanted ads.
  5. moose
    Fuel pump might not be needed, but then again it's a cheap upgrade.
    I think the stock pump can do 130lph, which in theory should support ~540cc injectors going full tilt.
  6. JJang12
    JJang12 Active Member
    it might be better off going with meth injection instead of bigger injectors + fuel pump.
  7. moose
    Injectors would be safer though. :)
