Ok so i know a bit of java but VB is just fricking owning me T_T. This is the GUI i have so far The radio buttons on the left are all named the same as the caption and the radio buttons on the right are all named as the caption with an "End" tacked on. For some reason when i try to call the methods( Atlanta. ) and the little list shows up, the only methods i see are "Count" "item" "LBound" "UBound" anyone know why?
i forgot all my java from 3 years ago, but i got an A in both VB6 classes, advanced one for elective. from the info you are giving me, I'm sure something is missing. What's in method (Atlanta). I still have my VB6 book to look at incase I need to.
Atlanta isnt a method. Atlanta is the label for the Radio Button Atlanta. So i want to do something like: If Atlanta.Value = true Then If BostonEnd.Value = true Then Label1.Caption = 1 End If End If but for some reason i cant get the .Value method to pop up. I only see those 4 methods "Count" "item" "LBound" "UBound" You can't do "and" in VB if statements can you?
Don't blame VB for your inability to use it. If you want, zip up and email me your project (christer.medin@gmail.com) and I will tell you what you did wrong. I do .NET programming as part of my job.
lol, it's fine now. me and a group of friends stayed up and did something different and somehow made it work. I just want to know this, Is it possible to declare global variables?
can you send me the VB program code? kthx. I might be able to help but I have not done any in two years.
