Wagon => Sedan front sway bars
Discussion in 'Modifications & DIY how-to' started by SkullWRX, Jun 26, 2005.
  1. SkullWRX
    SkullWRX Member
    Ok, I remember someone saying at install day that there was a set of control arms that would change the wagon geometry to a sedan geometry where the sway bar goes.... which year/model is this? And does it change anything else since the wagons have a 10mm narrower track on each side?
  2. GTscoob
    the older GC8 Impreza aluminum STI control arms bolt onto the wagons with some minor work.
    The sedan control arms will give you a lot wider track and you'll probably rub on the front since we dont have the flares.
    Why not just get a wagon front sway bar?
  3. Alex
    My point exactly.
  4. SkullWRX
    SkullWRX Member
    that's what i'm going to end up doing. I wanted something that went over 24mm (the highest wagon is 20-22-24 adj front), but to get these control arms is like 500+ for takeoffs.... not worth the investment. I was just exploring the other options. I'm gonna see Scott probably tomorrow about the new bar.
