Wagon-Specific Coilovers
Discussion in 'Modifications & DIY how-to' started by MarkM2016GTI, Jul 6, 2007.
  1. MarkM2016GTI
    A friend of mine was telling me that there are wagon-specific coilovers. Does anyone on here use these?. I may get coilovers for a stiffer ride. My H-techs are just too soft. I am looking at Cusco,Megan Racing and Whiteline. Any ideas?. I would really prefer the wagon-specific ones if somebody knows about these. My friend over here in Kauai has the Cusco Zero 2R's on his STi, but I don't have a need for these since I am not going to use them for auto-x.....I may in the future.
    Mark:coolugh:
  2. WJM
    Sedan ones will suffice. Just be prepared to buy some camber bolts to get the alignment in spec.
  3. Alex
    Why not consider just buying Koni inserts?
  4. socrates42
    socrates42 Member
    mark as far as I know no one makes wagon specific coilovers. I have the JIC FL-A2 setup, and I can not get nearly enough camber (front) with them because of the different lower. Now, the way they are designed they are independantly hight and compression adjustable, so you could get the lower mount made differently for wagons. If you can convince yoshi over at JIC in Cali to do it, I would buy the lower mounts as well.
  5. WJM
    or ya'll could just suck it up and get the sedan control arms.
  6. MarkM2016GTI
    I did hear from someone that the Koni inserts aren't half bad....
    Mark
  7. goixiz
    goixiz Active Member
    or you can slot them with a special ixizconcept tool :)
  8. WJM
    Konis are great.
  9. calmnothing
    /threadjack
    I have sedan rear control arms for sale, they already have the bushings pressed out so you can install groupN pieces
  10. slowwrx
    RCE has a wagon coilover I belive.
    Matt
  11. MarkM2016GTI
    Ming, can you PM me your new website. I would like to check it out.
    Mark
