wagon wheels?
Discussion in 'Modifications & DIY how-to' started by babygaines, Aug 4, 2008.
  1. babygaines
    babygaines New Member
    such limited options. am i wrong? ok my question is... what are the exact dimensions i need (off set, tire, and other wise) to put 18s on my 04 wrx wagon. or at least an idea of what parameters i should stay within when choosing 18s. i dont mind lowering a little, but i want no scrub issues and something thats bitchen but practical for a daily driver.
    please help... this money is burning a hole in my pocket!
  2. yerrow
    yerrow Active Member
    question is how aggressive do you want to go and are you willing to roll some fenders. currently i'm on shitty s-techs with an 18-7.5 +48 wheel and 225-40 tires. slight rubbage in the back when loaded in turns but nothing serious. my next set will be something much more aggressive...break out the baseball bat for rolling
    but there are planty of options
  3. undrgrndrdr15
    undrgrndrdr15 Active Member
    im not lowered but i have rota tarmac three's on my car... they were on it when i got it and im not a hundred percent sure but i believe they are like 8 inches wide... they are 18 and i dont believe the car is lowered... i have 245-45 and i have no scrubbing what so ever... everyone always ask if its lowered due to the bigger wheels... not sur eof an offset either... main thing is i have no scrubbing even with fat friends in the back of my car
  4. yerrow
    cuz its not lowered
  5. undrgrndrdr15
    yes but he said he doesnt mind lowering which means he may not lower the car... just trying to throw my two cents in cause every little bit helps if you ask me... clean wagon though man
  6. yerrow
    gracias
  7. GTscoob
    I wouldnt go much wider than a 225 width tire unless you're going with some stiff springs/struts or stiffer coilovers. The guys that have problems rubbing are having those problems due to running springs that are ~10-20% stiffer than stock but sitting much lower, the car still bounces around too much and you get rubbing.
  8. oneiguy
    oneiguy Active Member
    I was running S-techs with 17x7.5 on 225. Never rubbed once.
  9. SubiNoobi
    SubiNoobi Supporting Member
    The diameter of the wheel isn't nearly as important as the overall tire diameter and width. When you get a larger diameter wheel, you just get the appropriate tire size and your overall tire diameter will be very close.
    As many have said, 225 is about as wide as you want to go to avoid rubbing issues. People DO use 235 width or more on wagons, but that is dependent on other mods: roll fenders, lots of negative camber, very stiff springs etc...
    For example: if your stock size is 205/55/16 (that's mine anyway)
    you can get 17's with 225/45/17, this increases diameter by 0.41% (negligible)
    you can get 18's with 225/40/18, this increases diameter by 0.84% (again, negligible)
    For your wheels, you need some with 5x100 bolt pattern
    Stock offset is 53-55mm. VERY FEW aftermarket wheels actually come with an offset that high; most people just say go with 48 or higher. There are lots of wheels in the 48+ range.
    Also, if you look around there are MANY different kinds of stock subaru wheels out there: old RS wheels, 5x100 BBS wheels (from 04 STi's and others) and other different looking stockers. These are a great option if you are worried about fitment. However there are no stock 5x100 18's that I know of.
    Hope this helps
    Oh, BTW check out this wheel and tire size calculator, it can be useful:
    http://www.rims-n-tires.com/rt_specs.jsp?postId=906
  10. babygaines
    pimp!
    this sight is pimp!! long day, work sucks, more bills, dramatic girlfriend. but 8 replies to my question so far makes me remember whats important... my sweet ride!!!!
    -yerrow- how your car sits/looks, thats what i want. maybe an inch higher in the back but thats totally the look that im going for. thanks for your help.
    -subinoobi- so your saying that if i choose wheels that are 18s, 48+ with 225/40/18s, i should be ok and could decide on lowering once i see what they look like on the car?
    -undrgrndrdr15- are you happy with your rotas and how they sit? do you wish your car set lower?
    my final question to all is... what about wheel adapters? (pros,cons?) there some rims that i like (Drifz jade r 27b) though i cant find them anywhere in stock, that some say they will fit and some do not. ive been talking to a guy at eurotechnik auto sports that told me they have some that will work but i would need adaptors (i think because of the lug pattern?) and possibly spacers (i think because he's trying to sell me the 18x9.5s?) agree/disagree? or better yet go to this site (at the bottom of this post) and take a gander. i would love to here what ya'll think about them. its an ebay sight. the 2nd link is to the eurotechnik site
    thanks a heap!
    http://cgi.ebay.com/ebaymotors/18-D...ryZ43958QQihZ005QQitemZ150244536681QQtcZphoto
    http://etatuning.com/index.php?page...category_id=62&option=com_virtuemart&Itemid=1
  11. undrgrndrdr15
    i love my rota's... clean look and honestly i dont mind the height, the car looks like it sits low due to the big wheel and no fender gap...
  12. yerrow
    forget the adapters...not worth the trouble
  13. undrgrndrdr15
    good choice on no adapters... there are plenty of wheels out there man.... check import atlanta.com there might be some there
  14. undrgrndrdr15
  15. yerrow
    i would suggest since you have a wagon, to buy subaru specific offsets.
    link 1 on IA has the perfect example, i wouldn't recommend those "drifz" wheels for so many reason most of which is the offset +35.
    its easier with a sedan to get more aggressive offsets because of the fenders.
    i personally plan on trying a 18-8 with an offset lower than +42-ish. but if you buy something with a 7.5/8 width and around a +45 to +52 offset you should be in the clear
  16. yerrow
    not a chance in hell those 18-9.5's are gonna fit with or without spacers
  17. babygaines
    hey man, i still haven't decided on wheels. i want to go with rotas probably the p1 or the tarmac but i cant decide. your suby looks great with the tarmacs but i cant find them in flat black. i live in dawsonville. i would love to check out your car sometime. i just need some kind of visual reference before i spend all this money. any chance we could meet? ill come to canton if you could find the time.
    thanks
