I noticed this about a week ago, it happens on cold starts, it happens when it is both cold and warm outside, but it doesn't always happen...it goes away when the engine is warm, but it doesn't sound like "normal" suby noise. Just to be clear on what you are listening for...it's the psst psst psst psst psst psst. It is on the driver side of the engine, and loudest around the AC compressor. My turbo is hitting peak boost, and there is no fluctuation in the vacuum pressure. any ideas?
That was what I was getting at... I already checked that, the sound does not change with the ac on or off...it does change with engine revs though, speeding up and slowing down with the revs.
Sounds like an intake or exhaust leak, kinda hard to tell on video...have you pulled your Ic to check all the hoses and such?
Can you hear it more at the front or back of the engine? Top sde or under the car? Been over any big bumps or bottomed out lately?
