Well my cruise control stopped working...
Discussion in 'Modifications & DIY how-to' started by WRboXer, Oct 4, 2010.
  1. WRboXer
    WRboXer Active Member
    ...in my 02 wrx. Everything looks to be phsically connected and in good condition. Cruise control light still comes on when i push the button. Anyone gone through this before? Where do i start?
    My RS did the same thing...never did get it working again.
  3. b reel
    Maybe just the box is fried on the passenger side inner fender well. Might want to check with Brandon at Allpro
  4. Kokopelli
    check the switches on the brake and clutch pedals.
    They may look fine so you might have to swap with known good ones to test.
  5. bixs
    bixs Supporting Member
    the clutch switch on my old s10 made mine stop working...nothing else showed signs of failure.
  6. WRboXer
    It is the clutch switch, first thing i tried on the drive home yesterday was engaging the cruise with my toe behind the clutch pedal pushing it into the clutch switch alittle harder and it worked fine. Havent gotten underneath the dash to look at it, but i bet i can put some sort of spacer on the switch so that the clutch lever presses the switch more.
    Well see.
