But only in the rear passenger side. By chance I happened to reach back there and it was SOAKED...carpet and factory mat. Anyone have a guess as to where its coming from?
sunroof drain.open widow or sunroof.I assume this happened after it rained since it rains all the time here in ga.
whatever you do, make sure you leave your windows cracked to let it air out a bit. had this same issue in my old accord, and leaving the windows closed with high humidity caused the car to smell disgusting. hope you get it figured out soon
^^ I would clean it as much as possible and then have it professionally steamed cleaned. Best result.
One of my older cars, an 03, had a BB sized hole in the floorboard on the front passenger side. Pull up the carpet and look for one?
No fun at all. Hope you can figure out what the problem is. Hopefully nothing major. let us know if we can help!
^^^ have this guy clean it for you...great work. I bet the weather strip on your back door is to blame. Good luck man!
