What are the odds...
Discussion in 'Off-Topic' started by bluetwo, May 12, 2006.
  1. bluetwo
    bluetwo Active Member
    Feb 21, 2006
    1,512
    0
    What are the odds that I could get into SOG early as fawk tomorrow morning, say 8, and get front and rear sway bars installed before 10:00?
    They should have the Whitelines in right?
  2. FTZ
    Oct 10, 2004
    4,572
    1
    The rear sway bar is really easy to install, the front is a bit more difficult. Did you call SOG to see if they have them in stock. If they have it, they can most likely get it installed in the morning. Just call and see if you can set up an appointment.
  3. bluetwo
    Feb 21, 2006
    1,512
    0
    Fair enough. I just wasn't sure if they'd have em. Can't hurt to ask though.
  4. ScoobyMike
    ScoobyMike OG Mod
    Sep 24, 2004
    2,952
    0
    I'd say slim to none.
  5. miloman
    Feb 3, 2004
    12,774
    1
    i believe they have a lot of whiteline bars in... hopefully they have some that fit your needs
  6. bigb996
    Jul 5, 2005
    2,403
    7
    rear sway bar takes 15 minutes max, do it yourself man and save yourself the cash. It seems like anytime i need something for my car they never have it in stock, figures huh?
  7. jayj713
    jayj713 Member
    Feb 13, 2006
    827
    0
    How much does front and rear + install cost? 400 - 450?
  8. 1ll-WRX
    Jun 14, 2005
    2,819
    0
    I know.....They're evil like that :evil: They know what you want before you do...
  9. bluetwo
    Feb 21, 2006
    1,512
    0
    Yeah, I could still just pick the bars up while I'm in Atlanta this weekend, but they can't install until after lunch. Which I understand, and it was short notice.
    Installation would've been 300 for both which is actually way more than I wanna pay. I see why a lot of guys jump on those install days now.
    So... Diameters? Hit me with some suggestions.
  10. miloman
    Feb 3, 2004
    12,774
    1
    they may not stock a lot of stuff but they can order most of the things u need
    whats best for u depends on your current suspension setup... i had 26mm front/rear with 8k springs front/rear on my tein flex... it was stiff but real responsive... it would break loose real easy on lift too
  11. bluetwo
    Feb 21, 2006
    1,512
    0
    Ok. I've got the Tein SSP coilovers, which are basically the most comfortable Tein units if I understand correctly. I just want to go up about two notches firmer. How common is that set up like you had, with the same diameters front and back?
  12. miloman
    Feb 3, 2004
    12,774
    1
    since ur springs are softer, i think u would be happy with whitelines... i had the 24-26 adjustable front and 22-24-26 adjustable rear
  13. bluetwo
    Feb 21, 2006
    1,512
    0
    I got the 27 for the front. It's got three adjustments, so I'm thinking it's a 25-27, which I put on the 26 to start with.
    SOG gave me the STi piece for the rear so I have to wait until next week to get that one. :wtc: At least I know how easy it is to put on now though.
