What Is This Noise...help
Discussion in 'Modifications & DIY how-to' started by techlord, Jul 10, 2008.
  1. techlord
    Okay so on the 95 coupe I replaced both front axles, wheel bearings, and the drivers front ball joint...All appeared to be toasted anyways but this did not solve the noise.
    Any Ideas of what I should look at, missed, or should replace?
    the problem is a grinding noise that ALWAYS happens on a sweeping left turn, even if I am going straight and yank the wheel left you can hear it. It also does it when taking off in a straight line just for a sec.
    NEVER does it turning right.
    ideas?
  2. jt money
    i had the same thing happen on my bugeye and it turned out to be my rotor grinding on my caliper when turning cause of bad wheel bearing. i see you already replaced those so im at a loss.
  3. kingwrex
    kingwrex Supporting Member
    I Need To Come For A Ride With You
  4. Kokopelli
    You should sell the car before it becomes a money pit.
    I'll even be so kind as to take it off your hands for you.
    Seriously though , swing by my house this evening and take me for a ride.
  5. techlord
    King - Call me when you are on your way home.
    Mike - I will try to swing by later.
  6. Matt
    I've got the same thing on the driver side when turning right....I always associated it with a braking issue. I'm working on swapping brake parts out to hopefully fix the noise.
    my wheel bearing is fine, too
  7. kingwrex
    Will Do
  8. kingwrex
    WILL DO
  9. techlord
    ^^bring my rotors if they are done. ;)
  10. Trey
    Trey Active Member
    Fender liner maybe? If you take the wheel off you will see where the wheel rubs it. It does it to mine thanks to Will dumping it. :D
  11. WJM
    My vote is fender liner as well since the bearings/axles are new.
  12. techlord
    No rub marks what so ever.
  13. techlord
    Found it!!!
    Additional Hints:
    noise on throttle only.
    makes the noise very briefly on a missed start.
    Taking off, especially uphill or any load in a straight line.
    I fixed it in 20 min and had a spare lying around from previous endeavors.
    Any guesses?
    drained and refilled the tranny (Xtra S) and the grind in 2nd is gone. bonus here.
  14. WJM
    I give. I'm no good at diag over internetz/phone/txt.
  15. techlord
    busted tranny mount, had the 5mt's lying around and viola noise gone.
  16. techlord
    lol I can't spell while intoxicated, or sober for that matter.
  17. SonicBoom
    SonicBoom Active Member
    ^^ thats not spelled right? I know there's a ready made chicken/vegetable in a bag meal I used to call Chicken VO-ILL-A... anyways, back on topic..
  18. WJM
    yeah that works.
