What Should I get!!! Help!
Discussion in 'Modifications & DIY how-to' started by 1naplay, Jul 13, 2007.
  1. 1naplay
    1naplay Member
    what should I get, COBB stage 2 (TBE & Access PORT) or Turbo XS TBE & Utec System? I want something not loud and I know the Cobb is not loud at all, but I never hear the Turbo XS TBE. Or Should I just go with the TBE for now and forget the Access PORT or the Utec System, but still need to know which one. Help!!! :ddirty:
  2. jyang
    jyang Member
    I would get a cheaper TBE and get Cobb AP
    Cobb TBE is just way too expensive. It's a freakin metal pipe.
  3. keeganxt
    keeganxt Active Member
    Chin, I would definitely get AP over utec. Much easier to tune. You'll be much happier.
    As far as tbe are concerned, there are other quieter systems than cobb, borla hush for example but several others too. The turbo xs is not one of those. Jason with the black bugeye has one, its somethin serious. Very loud, I love it.
  4. SonicBoom
    SonicBoom Active Member
    Maddad whisper quiet is also not so loud. +1 for AP and getting a cheaper exhaust than Cobb. I bought all used... Helix catted dp - $250, Perrin cat-back - $350, Cobb AP V1 - $450. Going stage 2 for $1050... The AP can be found cheaper now (approx $350) making the whole set up under a grand if you shop right.......
  5. 1naplay
    1naplay Member
    thanks for the info, everyone else please give me feebacks too if you know what I should get, thanks:ddirty:
  6. socrates42
    socrates42 Member
    get the cobb AP and the MadDad tbe or any other TBE
  7. clemsonscooby
    clemsonscooby Active Member
    Buy everything used, that way you can get a lot more for the money.
  8. cannarella
    cannarella Member
    Find a used TXS Stealth Back that way you keep the stock axle back and it is not loud. You will get more turbo noise. That is what I am running with Cobb AP v1 stage 2. I kinda wish I had a little more grumble.
  9. Alex
    AP + Invidia n1 resonated if you want a nice angry v8 loud.
    The TXS RFL is ridiculously loud on the 2.5L.
