Trying to find out quicklike what of the parts listed below will swap over from a WRX to my 95 Impreza L... Front Sway bar? Rear Sway bar? Full Strut assembly Front and rear? thanks in advance!
Front doesn't. Rear does (if it has the brackets at the lateral links). Struts do but it'll ride high like a monster truck.
what about using the lowering springs on my current setup with the WRX struts? Are the lateral links the same as endlinks? I guess not since you did not call them endlinks. Still a noob on conversion.
a lot of things will fit...some will take more modification than others...some L's didn't come with rear sway bars, so the endlink bracket at the lateral link will be missing
There is a rear swaybar and it is tiny...slightly larger than a pencil. Any clue on the WRX struts with the current lowering springs so I aint ridin high?
13mm FTMFL!! :rofl: it might still ride a little high....also, I have my old suspension set up for sale. STi Ver 5 (GC8) struts Prodrive P1 (red) springs STi group N mounts in the rear cusco camber plates up front.... it rides JUST a bit lower than stock, but a HELLUVA lot more stiff...
cool so I guess you owe me some sways. I would like the WRX struts IF I can get to a decent ride height. If I wanted a monsta truck I would have kept the bronco. Here is my monsta truck, been meaning to post up a pic or 2. the resto and driveline, she was a beast.
