What's better?
Discussion in 'Modifications & DIY how-to' started by knhtrdr, May 29, 2006.
  1. knhtrdr
    knhtrdr Active Member
    Flex or Solid up? advantages disadvantages or differences.
  2. miloman
    theres been a lot of debate about these...
    flex:
    pros: flex section allows for some amount of independant motion at both ends... lower probability of breaking/cracking... easier fitment
    cons: some say that flow isnt as smooth
    solid:
    pros: some say flows better
    cons: being solid, it has no ablity to flex, hence greater chance of cracking/breaking... fitment may be more difficult
    my experience: i have always gone with flex uppipes... also i have never heard of a flex uppipe breaking whereas i have seen 3 solid uppipes broken at the flange
  3. knhtrdr
    Thanks
  4. suby113
    suby113 Member
    I agree! I had used a flex on my 04 worked great easier to install.
  5. knhtrdr
    Any particular brand of flex? or just go with what ever?
  6. miloman
    people have been happy with the gutted stockers... however i am not sure how good the flow will be since the inner diameter varies dramatically... however i doubt it will make much of a difference for a setup using a stock turbo... also its definitely cheaper to gut your stocker than buy another... plus the stocker flexes :)
    i had the PDE on my WRX and i liked it a lot... it has an accordian style flex section but if u look inside it, its sleeved and theres just ~1mm gap between the pipes on the 2 sides of the gap... i havent looked inside other aftermarket flex uppipes so i cant compare but it definitely looked smoother than a gutted stocker
  7. nsvwrx
    nsvwrx Active Member
    peopel have dyned stock gutted vs HIGH end and have seen virtually no diff, in some cases the stock did better due to the thermal sheilding
  8. moose
    My personal opinion:
    I prefer solid, and have no concerns about it cracking as long as the install is done properly.
    Have had a Perrin on for something like 14k miles without issues.
  9. clemsonscooby
    clemsonscooby Active Member
    No difference. Buy whatever is less money and use it. I have a solid HKS that has worked fine for over 2 years now. Use the correct torque specs and gaskets, there should be no problem.
  10. Cool_____
    I have the Ebay ERZ flex on mine....and well it's been proven ;)
  11. siegelracing
    I've seen 10 broken, cracked, or leaking solids. I've never seen a SINGLE problem with a properly installed flex...
