hello, i have a 04 sti, i have the following: gt30r turbo kit perrin fmic w/t-bolt clamps...you need them,trust me! spt exhaust axxis 18" rims tein springs exedy clutch cobb sway bars hawk brake pads (2) perrin wing stiffis liscence plate delete radiator shroud short shifter mmmm...fuel pump,injectors,and gauges. i think thats it. maybe looking at a meth kit but need new ecu. i have ecutec now. what do yall think?
license plate delete? hmmmm I would suggest beefing up the hubs. 6gunracing.com has a stellar hub conversion!
By license plate delete I'm thinking he means the front license plate. What's next? LS1 SWAP!!!! WOOOOO!!!! Or maybe some full coilovers? Also get 2 more perrin stiffies and get that WRC look goin' on.
nooooo, perrin makes a license plate delete.scott tuned it the first time and then i took it to doug after my turbo upgrade just because i wanted some numbers on paper. it made 399.19 hp and 378.60 trq. can i have different maps that i change to easily with the ecutek? ohh pics coming soon
Nope. The only ECUs that had map switching were 02/03 WRX Ecus. You can put them in 04 or newer cars and still have map switching but on an STI you'll lose AVCS control. I'd suggest some braking or suspension mods to balance out the added power. You didnt specify which Tein springs you're running but I'd get something a little stiffer, maybe Prodrives, Racecomp, or Espelir. Sway bars would also be good. Grippy brake pads too.
