I am feeling a grinding noise/vibration. It is only noticeable when decelerating even when brakes are not applied. If this is the case what would the cost be? Also, could the issue have been caused from a recent tire rotation? I appreciate any help. Thank you gang
contact wheel bearing Wes at Allpro, you'll find their number under the vendor section. if from wheel rotation then it may just be a loose rim so torque the lug nuts
