Where to get Helix catted DP
Discussion in 'Modifications & DIY how-to' started by moose, Mar 1, 2005.
  1. moose
    Looking to pick up a catted Helix downpipe. Anywhere local worth looking, or am I best served ordering online?
  2. ScoobyMike
    ScoobyMike OG Mod
    no where around here has them. You would be better off searchin the web. Milo got his from Grupe-s I believe. I will post later once I find the site where I got mine from.
  3. longfury
    longfury Active Member
    Have you tried Topspeed yet? Porter should have it and if he doesn't he can get it fairly quickly.
    678-297-7770
  4. miloman
    i got mine from gruppe-s
  5. moose
    Saw they have it for $399 shipped.. might give topspeed a call and see if they can beat it.
    Milo, did you replace all gaskets when you installed yours? Any leak problems?
  6. miloman
    replaced all gaskets... mike and i both had a leak, but we ended up using double gaskets at the joint where the dp meets the catback section and have had no problems since
  7. moose
    Cool, thanks. Did you use the stock Subaru gaskets or the subydude ones?
    I'll probably order the DP pretty soon... the AccessPort appears to have a couple of issues I'd like resolved before ordering one so might wait on that a bit.
  8. miloman
    well... it came with its own gaskets but we needed an extra one... scott at SOG cut an extra one out for me and installed it
