whistling noise upon IC install
Discussion in 'Modifications & DIY how-to' started by Goose013, Apr 27, 2006.
  1. Goose013
    Goose013 Member
    I installed my hyperflow tmic while ago and then cleaned the inside of my forge bov, I was wondering what could be making the whistling noise upon boost? could it be my bov or the tmic, maybe a hose not tight or something. any advice would help. oh yeah, i'm still using my stock air splitter which doesn't form a seal too well. thanks
  2. moose
    You have a leak somewhere, as you've figured out. Maybe you didn't tighten the y-pipe or BOV down, or maybe you bungled up a gasket somewhere.
  3. Goose013
    Goose013 Member
    it sounds hillarious, just making sure it was nothing serious. I like to screw things up ya know. thanks i'll check the pipes
  4. Alex
    I think all evidence points towards yes.
  5. miloman
    i had that SAME noise yesterday when i installed mine... if u used 1 gasket for the BOV, try using 2... that fixed my problem
  6. WrxCrazy
    WrxCrazy Active Member
    yeah 2 gaskits work better then 1.. makes it alot tighter
  7. Goose013
    Goose013 Member
    I had that same idea and it worked, yay.
