Whiteline FSB install
Discussion in 'Modifications & DIY how-to' started by SubiNoobi, Jul 9, 2007.
  1. SubiNoobi
    SubiNoobi Supporting Member
    OK, so even though I already put the bar on, I looked up the how-to on scoobymods and here is what i find:http://www.scoobymods.com/forums/showthread.php?t=336&highlight=whiteline+front+sway+bar+install
    Put it on backwards? I'm sorry, but without pics this doesn't seem credible at all. Has anybody heard of this method of installation?
    I put it on with the same orientation as the stock bar. There is more noise, but I figured that was part of the whole deal with stiffening the car?
  2. BrianGT
    nah, don't put it on backwards... but make sure to lube if up real good, so that it is able to rotate in the bushings well enough to do it's job. Did you lube it good?
  3. SubiNoobi
    yeah, it rotates fairly easily by hand.
    But seriously, how does that guy get to do a writeup on scoobymods with that kind of random BS?
  4. BrianGT
    no clue.. but I ran the whiteline bar for a while, and it was a great bar.
  5. clemsonscooby
    clemsonscooby Active Member
    What size were you running?
  6. BrianGT
    The x3006 XSF36XXZ - BSF36XXZ (whatever they call it now) whiteline bar was what we were running before we switched to the Strano bar. IMO, the strano bar was significantly stiffer, and we will run it until we put on coilovers with higher spring rates, and then we will play around with going back to a lesser front bar.
