Whiteline vs. Perrin
Discussion in 'Modifications & DIY how-to' started by Deke, Mar 8, 2006.
  1. Deke
    Deke Active Member
    I've noticed everyone here seems to go with whiteline sways. I've always planned on getting perrin when I get mine, especially since there rears come with upgraded mounts. Any reason why everyone likes whiteline?
  2. sol drums
    sol drums Active Member
    don't know. i have the perrin rear on mine & was going to buy the perrin front.
    i'm sure someone will chime in
  3. Goose013
    Goose013 Member
    Whiteline has been making racing products in Australia for a long time; especially for subies. I would think they know what they are doing by now, but when it comes down to it Perrin is as good as the next from what I can tell. You do however get more choices with the Whiteline sways. just my opinion.
  4. rolling_trip
    rolling_trip Active Member
    trust me,i am a perrin whore! but i went with the whiteline fsb. i maybe wrong but bigger is better when it comes to swaybars and hanlding, and perrin fell a little short. it made a night and day difference, and might be the best mod for the $.
  5. trhoppe
    trhoppe Member
    Its kind of what Goose said. Whiteline has been making products that work for a LONG time. They also offer the most options, allowing you to pick between a 22mm up to a 28mm bar on either end of the car. This allows you to fine tune to what you want. Also, they are fairly inexpensive and good quality. I personally used whiteline prouducts because at the time, they offered the biggest front sway bar possible for an Impreza. Last but not least, Whiteline also offers upgraded mounts. While they are a good investment for under an 04MY, the 04 and above already has reinforced stock mounts from the factory, which are just fine with 24mm rear bars. Bigger then that (which would only be required on an autox WRX w/o adequate spring rate) and you should upgrade.
    -Tom
