I'll provide a cooler stocked with beer for any/all (21+ Y/Os) that want to come help out putting some stuff on my whip. So let me know if you'd like to help installing: Koni inserts (already in stock shock bodies) SS lines and fluid change VF39 STi TMIC one step colder plugs Kartboy shift bushings Kartboy rear endlinks modding injectors fuel pump new 3" gaskets for my TBE Cobb VF39 map flash (long enough to drive it to SOG for a tune) Oil change (motor and tranny) I obviously have a lot to do... More than a full day even with help. So, if anyone wants to pitch in, it'll be in a HEATED garage in Kennesaw. I was thinking about trying to do it all this weekend, but if I can get some help I'll hold off till next or after that.
Yeah. I have a bunch of stuff. My spring compressors suck, but maybe it won't be too bad to do it without them? I'm starting to think about doing the suspension and brake stuff one weekend, then the engine the next. It's just too much to do in one day.
Is this at your house? I could walk over and help you. At least, I can lend you my spring compressors.
I can help on Sunday. As far as modded injectors go I strongly recommend against modding them and throwing them on the car without testing. Mine flowed between 850 and 950 when static. here are my test results:
From what I've heard they're the same as pinks, only not pink. If I can find some at a fair price I'm going to get them. I'll need to buy a set of injectors someday when all this comes back off. Alex- it's at my house in Kennesaw that has a heated two car garage and tools. I'm too much of a wimp to do this in the cold... I was thinking about doing the suspension this weekend, and putting the turbo on next? I don't know.
I've done 4 sets for friends that got flow tested and every one of them has been nearly perfect, I think the worse case I've seen is 3cc diffrence. I've ran them on the bugeye and they work perfect.
Yesterday I put on the Konis... I'm waiting on the brake fluid and gaskets that are coming from Fastwrx.com. I thought they were here, but that was something else I ordered. It looks like I'm going to put this off 'till next weekend I'll probably use this Sunday to work on the defuser for the larger TMIC... So if anyone's free NEXT Sunday (1/21) I'll be under my car. :eek3:
