Will 04 WRX springs fit 06 WRXs?
Discussion in 'Modifications & DIY how-to' started by jayj713, Oct 22, 2006.
  1. jayj713
    jayj713 Member
    Couldnt seem to find this anywhere but maybe im just newb at searching :/
  2. Alex
    It should, considering the strut design hasnt changed for the impreza yet.
  3. miloman
    i dunno bout that... bluetwo had some problems when he ordered coilovers... they were designed for an 05 and they wouldnt fit his car if i remember correctly
  4. SkullWRX
    SkullWRX Member
    A change was made in 05 for Sti, but WRX changed in 04. So any 04+ spring should fit the 06. They are slightly longer (if i remember right) than the 02-03. If you have a set in mind and want to be absolutely sure, ask the vendor. A lot of them will give you a straight answer of point you in the right direction.
  5. jayj713
    jayj713 Member
    Yep, found on nasioc that Tanabe GF210s will fit 04-06 WRXs and 04 STis
