Will these fit?
Discussion in 'Modifications & DIY how-to' started by savsuby, Nov 13, 2006.
  1. savsuby
    savsuby Member
    I was just wanting to know if the 27mm Whiteline swaybars will fit on a 2005 wrx front and back.
  2. bluetwo
    bluetwo Active Member
    I have a 27mm Whiteline on front my WRX and 26 in the rear. Mine are adjustable though: My front = 27,29 and rear = 22,24,26
  3. FTZ
    Are you sure the rear is 27?
  4. Alex
    I wasnt aware they made a 27 rear either...
  5. savsuby
    savsuby Member
    I think I will call Scott at SOG
  6. longfury
    longfury Active Member
    They do. BSR33XXZ I think is the part number. BSF33XXZ is the front one.
  7. clemsonscooby
    clemsonscooby Active Member
    The best way to see if something fits is to find a place that sells it and check out their application guide. http://www.gruppe-s.com/Subaru/subsus.htm. On the gruppe-s it says that that bar is made for any 02+ WRX. So yes, it does fit.
  8. savsuby
    savsuby Member
    thinks guys
  9. siegelracing
    They do have a new 27 rear bar. I only suggest that if you do a lot of auto-cross. Savsuby, the 27 front bar is always good (as long as you have a sedan, they don't fit the wagon) The 22-26 adjustable rear is normally the match. If you do alot of auto-cross it might be worth trying the 27 rear.
