will this fit on 03 sedan?
Discussion in 'Modifications & DIY how-to' started by mokinbird87, Aug 29, 2007.
  1. mokinbird87
    mokinbird87 Active Member
    just trying to make sure before i install them... my vin # is JF1GD296736503192
  2. mmtasty
    mmtasty Active Member
    what does the date stamp say on your door?
  3. mokinbird87
    sorry to take so long to find out (my car has been in the shop).. my car was made in july of 2002.
  4. clemsonscooby
    clemsonscooby Active Member
    You can always take the pads you have on there now off and look at them...
  5. mokinbird87
    dont have the tools to take them off...
  6. clemsonscooby
    Your car comes with a jack. You just need a 12mm wrench and a brake spreader, probably less than $20 for the both of them. This way you can do the brake job yourself in the future also.
  7. WJM
    you dont need the speed bleeder to do pad replacement...
  8. clemsonscooby
    ^^^right, you do need a brake spreader.
  9. WJM
    ah ha! thats what you were trying to say.
  10. clemsonscooby
    I've always found that the caliper compresses a little bit when you swing the pads off. With the spreader I was easily able to get the pads swung back onto the rotor. These tools are a must for everyone. Imagine if you had brake trouble and SOG couldn't fit you in until a few days later, what would you do... hope your brakes worked around that next corner... have your car towed to the shop... borrow your moms car...
    http://images.solidcactus.com/autobarn/xxxw-lis24400.jpg
