Window Tint Citation
Discussion in 'Modifications & DIY how-to' started by shiftynick, Jul 15, 2008.
  1. shiftynick
    shiftynick Member
    Son of a biscuit eater.. I got hit this morning for speeding this morning right in front of Global Imports BMW on Interstate North Pkwy. 54 in a 35... what is 19 over going for these days in Cobb county?
    I don't really care about that, but it must be quota time because he decided to get me for my tint too.. :mad: The reader said 14%. Has anybody been hit with this in the last couple years? The law says max fine of $1,000 and 12 months imprisonment. (40-8-73.1) Even though beeotch wrote 40-8-76.1 on my ticket, which is a seat belt violation... (wonder if I can get off on a technicality). I was about to get this tint taken off too, because it was so crappily done... arrgrghhh!!!!
  2. nsvwrx
    nsvwrx Active Member
    And yes you can get off with a technicality.
  3. JJang12
    JJang12 Active Member
    were you clocked by radar or laser?
  4. shiftynick
    shiftynick Member
    Well technically it says this:
    OFFENSE (Other than above) "Improper window tint"
    In violation of Code Section "40-8-76.1"
    REMARKS: "14% driver's window #22515"
    Everything in quotes it what he wrote. Only the code section is wrong..
  5. shiftynick
    shiftynick Member
    Laser
  6. socrates42
    socrates42 Member
    you can still get out of it b/c of that
  7. Jake
    but if you were going to remove you tint regardless because of the shitty job, why not just remove it and go down to the courthouse the next day. 99.9% of the time if you go show a court recorder/secretary(whatever they are) they will just drop the charge all together thats what i did. I got hit for it in Jackson, GA and went to the courthouse with my car stripped (i did it myself for free) and told the lady, "I was told by the officer that if I came up here and showed someone I had stripped my tint that the fine would be dropped???" and she said "yeah, ok" and proceeded to follow me out to the car and check. then that was it.
  8. Strayen
    Strayen Active Member
    Well I don't speed if I have to drive in front of Global Import BMW because I've seen lots of cops there. I work very close and drive past there on my way to the Cobb Galleria area for food or whatever. I'll have to be extra careful.
  9. shiftynick
    shiftynick Member
    how did you go about removing your tint? i was thinking of trying the ammonia on a garbage bag method. i also have a heat gun...
  10. FTZ
    I don't think a heat gun will be any help. Go to Advanced Auto or Pep Boys, and they sell a tint removal spray for cheap. You don't need it 100%, but it definitely helps. Just that and a razor blade.
    Removing tint is a PITA. If you do it slow, you can get it in a couple of large pieces. If you go to fast, you will be removing little slivers of the tint, and it will take forever.
  11. blindfold
    blindfold Active Member
    worse comes to worst, get some blades and start scraping
  12. Cool_____
    Do NOT use blades on the back glass unless you want your rear defrost to stop working.
  13. FTZ
    Yes, good point. I wonder how you remove tint from the back then?
  14. Cool_____
    Best way is take plain old Windex and spray down the back glass HEAVILY. Lay a towel over your back seat and deck to keep from water spotting. Then get a black trash bag and lay it on the window and let that thing bake in the sun for 3-4 hrs. Then SLOWLY peel the tint off. After that some Goof off will get the residue off but most of it should come up with the tint if you can get it hot inside.
    Oh and spray and put the trash bag on the inside of the glass obviously.
  15. Jake
    not sure if it was due to the quality of the install or just the type of film (i believe it was ceramic 20% llumar), but i just got a razor blade in the corner and EVERY window including the back glass came off in one easy tear. I was very careful on the back glass as well. then after it was gone went back with some windex and cleaned up any residue left behind.
  16. Doubtful, but it's all up to the judge..... but if the tint was coming off anyway may as well take advantage of it :)
  17. 07Ltd#767
    wow, that sucks dude...nobody drives 35 down that stretch, we put in when we shoot the hooch right there past BMW and people fly down that road.
    On a side note, if you want to redo your tint at somepoint in the future, get a hold of deanjones on this forum...he did my tint job at legal specs and it looks fantastic, price was pretty good, too
  18. ballistic
    ballistic Member
    the cop was probably cutting you a break, i think a seat belt violation is one of the cheapest out there. my dad got the same kind of ticket and the cop said that was the cheapest ticket they could give and the money was donated to some foundation
  19. quazar
    quazar Member
    Were you coming from the Cumberland Mall side just south of I-285 and they were sitting under the bridge shooting?
    They love hiding out there and hittin' people as they come down the hill.
    Be careful.. they also like to shoot on Circle 75 Pkwy and Windy Ridge Pkwy as well.
  20. wrx_kid
    wrx_kid Member
    i got a speeding and tint ticket juss a while back
  21. wrx_kid
    wrx_kid Member
    i think he cut u a break he aint cut me a break tho
