window wont roll down
Discussion in 'Subaru of Gwinnett PD' started by knhtrdr, May 8, 2006.
  1. knhtrdr
    knhtrdr Active Member
    My passenger side window just stopped working today all other windows work fine. is this a fuse issue and if it's not is it coverd under warranty?
  2. Alex
    Depends on your milage, but it should be a warranty related fix it.
  3. knhtrdr
    ^^ Thanks, The crazy thing is it was working fine when I left work. went over my friends house and it just stopped workin when I got back in the car.
  4. jt money
    does it work when you use the passenger side switch rather that the drivers side one? just woundering. if it does then it sounds like a short on the drivers side. not really sure if this is fuse related but it doesnt sound like it is.
  5. WrxCrazy
    WrxCrazy Active Member
    maybe the roller power window relay gone bad
  6. knhtrdr
    It does not work on eithier side.
  7. jt money
    then wrxcrazy might be right. i would guess it the motor or the relay for the motor thats giving you problems.
  8. knhtrdr
    Took it to sog today a really quick fix!
