wiper sprayer clogged
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, Jul 26, 2011.
  1. Mad Mallard
    Mad Mallard the mad mallard
    the drivers side is basically useless.
    is there anything i can try to unblock it?
  2. nsvwrx
    nsvwrx Active Member
  3. Mad Mallard
    i dont think running it thru would be good.
    how else would i use it? toothbrush?
  4. Cool_____
  5. Mad Mallard
    call me crazy, but felt like a little human interaction with the 'community', not rtfm
  6. b reel
    put the part in a small container of CLR. It's called thinking outside the box
  7. lsnaple
    lsnaple Member
    I cleared mine with compressed air and a small wire. That reminds me, I need to aim them down just a tad.
  8. talos
    talos Member
    ditto....remove just the nozzle and blast some compressed air backwards through it, a needle or small wire would help too.
  9. Mad Mallard
    whelp i tried to get some compressed air thru it and the air nozzle didn't quite like the opening.
    So i went to take the the sprayer nozzle out, and uh...
    ...how do i do that?
  10. Cool_____
    Look under the hood and you will see the hoses. Disconnect and then pop the piece out. You have to squeeze the tabs and it will slide right out.
