Im looking for a good turbo timer that is easy to install. I ran into jwolf? at petco last night and he showed me his but i forgot the make of it. Thanks in advance.
nothing will cool more efficient than a normal to slow drive around the block prior to turning it off
Yeah I agree, it is not necessary. I have one and keep it off most if not all the time due to its annoyance.
^^I said the same thing in the beginning, now I cannot stand it. But if you must I have the greddy and it works well.
yeah, turbo timers are pretty much unneccesary. I'd say if you want things that you don't need get a cai or a bov, at least then it'll sound cool.
I have one I will sell you for $75. It is like the one displayed but the silver part is carbon fiber and the screen is green and matches the interior lights almost perfectly. It flashes green and red when it is counting down. I even have the pnp harness I will include. I am not sure it will work on the 04 but if its the same wiring as the 03 it should work fine EDIT/ its a Blitz FATT DC3 here is some info on it The BLITZ FATT (Full Auto Turbo Timer) DC 3 has a compact face design which allows the face unit to be virtually mounted anywhere in the vehicle. Features Manual Timer- Allows the user to preset count down time. Automatic Timer - The FATT DC 3 has the ability to calculate the count down time by the how the vehicle was driven. There are 5 different types: -A-L - will start to calculate time automatically after 1800rpm. Low setting -A-S - will start to calculate time automatically after 1200rpm. Medium setting -A-H - will start to calculate time automatically after 900rpm. High setting -E-L - will start to calculate time according to how long the ignition has been on. Adds 55 seconds per hour. -E-H -will start to calculate time according to how long the ignition has been on. Adds130 seconds per hour. Voltage Display - The FATT DC 3 has a built in voltage display. This allows the user to monitor the vehicle's charging system. Temperature Display - The FATT DC 3 also has a built in air temperature display. This allows the user to monitor the cabin temperature. Stop Watch and Lap Timer - This unique feature allows the user to use the stop watch function and also can record up to 5 lap times.
I got an HKS type 1 and mounted it in place of the clock. I like it but can be distracting at night. Perfict fit no cutting at all, that was enough for me..
I want one too just because I have a bad habit of not waiting sometimes when in a hurry. even though its only happened twice,two times to many for me. It will be used as a prevention method for me.
