WJM: can you write up a Coolant service sticky
Discussion in 'Modifications & DIY how-to' started by goixiz, Aug 29, 2007.
  1. goixiz
    goixiz Active Member
    Oct 23, 2005
    1,482
    0
    I cant recall all the steps that you mentioned on how to service my coolant
    There were a few steps and if i recall not your ususal steps
    thanks in advance
  2. baddriver
    baddriver Active Member
    Feb 22, 2006
    836
    0
    I have this saved from Unibomber on NASIOC:
    http://forums.nasioc.com/forums/showthread.php?t=504002
    Here's a gif of a procedure that looks to be current as of sometime in 2004:
    #2 baddriver, Aug 29, 2007
  3. goixiz
    Oct 23, 2005
    1,482
    0
    yes i have that but I remember WJM mention a different procedure that get more of the old coolant out and has less trapped air
  4. WJM
    Dec 12, 2004
    5,401
    0
    Drop the lower hose and pull off the t-stat housing and pull the t-stat out, that will drain 95% of the coolant.
    Make sure to use a NEW t-stat gasket...and a new t-stat is recommended as well.
  5. goixiz
    Oct 23, 2005
    1,482
    0
    what about burping and getting all the air out
  6. WJM
    Dec 12, 2004
    5,401
    0
    If i told you that...I wouldnt have a job now would I...;)
