wtf!
Discussion in 'Modifications & DIY how-to' started by JEFFSTI, Mar 24, 2008.
  1. JEFFSTI
    JEFFSTI Member
    ok. just got my new clutch in a month ago or so. when ever i try to go over to reverse it is really hard. i feel like im going to break it! no problem going into any gear just getting over there. any hints?
  2. XanRules
    XanRules Active Member
    What kind of clutch?
  3. BrianGT
    more lube?
  4. WRXCoupe
    WRXCoupe Active Member
    Yeah, what kind of clutch, stock? I have an 02 my stock clutch is still good, but 1st and reverse still and always have required the double pump depending on the weather a single or triple pump is appropriate. Hydrolic systems, seem to me, to be more barometric pressure sensitive and with Suby's you have the syncro issues as well depending on the year.
  5. dontcallitarex
    dontcallitarex Active Member
    FWIW, my 03 forester did this and so does my current car. My dad used to complain about how difficult reverse was. I think the manual to the 08s even addresses it; something like "If engaging reverse is difficult, return the shift lever to the neutral position, re-engage the clutch, and try again." I remember thinking "Or you could have just fixed it....?" lol
    Gotta love Subaru.
  6. Matt
    FWIW, a lot of transmissions are like that. some companies like ford, you have to go to first first, and then to reverse. I've done that with my Subaru and it usually helps with getting it right. Does this happen all the time, or just when it's cold?
  7. JEFFSTI
    JEFFSTI Member
    its a exedy stage2. 3 puck. its not going into gear at all. just going over to reverse. i have a sti. you have to pull up that round disk and push it over. that is what is sticking
  8. WJM
    Normal. Ever since subaru put the syncro on reverse its been more difficult to get into.
  9. Berzerklo
    Berzerklo Active Member
    Yeah my Integra used to do that too. I think that is one of those problems that it would just be a stupid amount of $$$ to fix something that is a nuisance more than a real problem...
  10. Doug@DBW Motorsports
    try putting it in second then reverse. You need to put it into second to stop the shaft in the tranny from moving.
  11. WJM
    Now all you ppl who laugh at me for doing so can bow down to the WJM!!!!!!!!!!!!!!!!!!!!! :bowdown:
    :rofl::rofl::rofl::rofl::rofl:
    Seriously, that works, every time.
  12. Deke
    Deke Active Member
    I' m more of a put the car in neutral and repress the clutch kind of guy.
  13. JEFFSTI
    JEFFSTI Member
    i dont think that it has any thing to do with the clutch. it goes into gear just fine
  14. FRCFED4
    FRCFED4 Member
    the clutch would be the problem, if its not disengaging all the way or something along those lines.
  15. JEFFSTI
    JEFFSTI Member
    fixed it. It was just the brackett. works like a charm now
  16. WJM
    bracket? at the trans?
  17. techlord
    prolly the bracket that the rev lockout goes into the linkage...I left mine off and had that problem the rememebered oooops gotta put that on.
    Remember filler up with Extra S and all will be smooth as buttuh.
  18. JEFFSTI
    JEFFSTI Member
    thats the one
