Zen Motors - APR Performance, Seibon Carbon, Wings, Splitters, Diffuser, Mirrors!!!!
Discussion in 'Vendor "For Sale" Classifieds' started by ZenMotors, Mar 23, 2009.
  1. ZenMotors
    ZenMotors Member
    APR Performance Specials!!!
    APR GTC 200 Wing:
    Vehicle Type:
    Compact Sports Cars
    Circuit Method:
    Road Race & Drift
    Average Track Speed:
    Up to 160 mph (257 kph)
    Description:
    Spanning 59.5 inches and a height of 10 inches, the GTC-200 adjustable wing offers the perfect amount of downforce for midsize and compact cars
    PM for special Zen Price!!!
    APR GTC 300 Wing:
    Vehicle Type:
    Sports Car or Widebody
    Circuit Method:
    Road Race & Drift
    Description:
    With a span of 67 or 61 inches and a height of 13 inches, the GTC-300 is an adjustable wing that means serious business. The GTC-300 3D airfoil shape allows for optimal airflow that reduces drag yet supplies an effective amount of downforce.
    APR GTC 500 Wing:
    Vehicle Type:
    Circuit Method:
    Top Speed
    Up to 180 mph (290 kph)
    Description:
    The newest addition to the GTC Series is the GTC-500 Carbon Fiber Adjustable Wing. Spanning 70 inches, the GTC-500 is the largest aftermarket adjustable wing available. With its optimized 3D airfoil shape, the GTC-500 is perfect for high speed touring applications and supplies an ample amount of downforce without causing excess drag.
    PM for Special Zen Price!!!
    APR Splitter
    To combat the effects of front end lift, APR Front Wind Splitters are utilized to give extra traction and control in the front of a car. By creating a high pressure area on top of the wind splitter, high pressure air flow is restricted to flow underneath a car. With low pressure below the car, the effect of lift is reduced and a driver can gain from the extra traction and control.
    Features:
    • Carbon Fiber Reinforcement
      All APR Front Wind Splitters are reinforced with sheets of carbon fiber.
    • Fully Functional Undertray
      Our Front Wind Splitters are not just add on cosmetic pieces. Every APR Front Wind Splitter completely covers the entire area below a cars front bumper. This allows for smoother air flow below the front bumper, creating more efficient downforce.
    • Support Rods Included
      Supporting every APR Front Wind Splitters are stainless steel Support Rods.
    APR Diffuser
    Diffusers work in conjunction with other aerodynamic components of a car to help produce downforce. Because a car displaces air as it moves forward, the air molecules in the rear of the car get disrupted causing a vacuum of low pressure air.
    To help channel the high speed air flow coming from underneath the car, diffusers redirects the high speed air flow to transition smoothly transition into the low pressure vacuum in the rear. This encourages a smoother flowing air flow underneath the car and allows better performance from other aerodynamic components such as aerodynamic wings. Available in
    PM for your Zen Price!!!
    APR Subaru Front Air Dam
    Underbody components such as front air dams, undertrays, and rear diffusers are essential for maximizing aerodynamic performance. The APR Performance Front Air Dam integrates with the factory front bumper to:
    - Reduce lift.
    - Increase front-end stability.
    - Improve high-speed cornering grip
    This Front Air Dam also utilizes a built-in aerodynamic splitter design that creates a high-pressure region of air atop the protruding surface, further reducing lift and increasing net downforce.
    APR Formula Mirrors
    When it comes to reducing aerodynamic drag to a car, the APR Formula GT3 Mirrors are an excellent choice. The APR Formula GT3 Carbon Fiber Mirrors are designed to give race inspired looks with the functionality of reducing drag and eliminating blind spots with wide angle mirror lenses.
    Features:
    • Carbon Fiber Construction
      All APR Formula GT3 Mirror housings are reinforced with layers of carbon fiber sheets for weight reduction and added strength.
    • Wide Range of Adjustment
      Every Formula GT3 Mirror include a left to right pivot arm at the mirror housing with an adjustable ball stub rod to allow a wide range of adjustment.
    • Aerodynamic Shape to Reduce Drag
      These carbon fiber mirrors are compact and aerodynamically shaped for a low drag coefficient.
    • Billet Aluminum Bases for Easy Installation
      Lightweight & durable billet aluminum mounting bases are specifically designed to factory specifications for easy installation and clean fit and finish.
    • 5.5" Wide Angle Convex Mirror Lens
      Convex lenses are used on both driver and passenger sides mirrors to eliminate blind spots. Blue anti-glare mirror lenses are included to reduce reflections from headlight glare during nighttime driving. Please note: Blue anti-glare mirror lenses found only on 5.5" wide APR Formula GT3 Mirror housings.
    • Mounting Hardware Included
      All screws, bolts and mounting gaskets are all included to allow you to install the APR Formula GT3 Mirror to your car
    PM for Special Zen Prices!!!
  2. ZenMotors
    ZenMotors Member
    Seibon Carbon Fiber Products!!!
    Here are some pictures of their Dry Carbon Series!!! HOT!!!
    Don't see something you like? Give me a call! I carry many brands that are not listed above.
  3. ZenMotors
    ZenMotors Member
    Bump for Specials!!!
  4. ZenMotors
    ZenMotors Member
  5. ZenMotors
    ZenMotors Member
    Bump!!!
  6. ZenMotors
    ZenMotors Member
    Get your APR Parts, and Seibon goodies today!
  7. ZenMotors
    ZenMotors Member
    Bump for Zen!!!
