Zen Motors - Coilover Specials!!! Stance USA, BC Racing, and Tein!!!!!
Discussion in 'Vendor "For Sale" Classifieds' started by ZenMotors, Mar 13, 2009.
  1. ZenMotors
    ZenMotors Member
    Zen Coilover Specials!!!!
    Stance USA
    Get your Stance Coilovers today from Zen Motors!!! We can have tracking number within 24 hours of transaction!!! We are eager to earn your business!!!
    Stance USA has a great product line that you should really give a try. They are made in Japan. They have a wide variety of applications that suits your needs, and Budget! I am personally running them on my Time Attack car myself.
    Stance LX+Plus
    The LX+Plus was designed for the enthusiast that wants greater performance than their standard dampers without sacrificing ride comfort. TheLX+Plus uses twin-tube technology to give a unique, luxurious ride quality. 15-way adjustable damping allows the driver to tune the shocks for any condition or handling characteristic.
    Retail: $1395.00
    Call, E-mail, or PM for Special Pricing!!!
    Stance GR+
    The GR+ is our flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. Camber adjustable upper mounts are used on strut types.
    Retail: $1429.99
    Stance GR+ Pro
    The GR+ Pro coilover has all the features of the GR+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.
    Retail: $1529.99
    Stance SS-D
    The Special Setting Dampers were developed to meet the special demands of the circuit. The SS-D is valved to work in conjunction with race tires to maximize traction. The GR+ Pro SS-D were used to win national titles in both drifting and time attack; setting the highest benchmark for itself - winning.
    Retail: $1529.99
    Stance AL+Pro
    The Stance AL+Pro has all the features of the GR+ Pro, but uses an anodized forged aluminum shock body. This increases anti-corrosion properties while reducing unsprung mass, enhancing all aspects of performance without any drawbacks.
    Retail: $1895.99
    Stance GR+3-Way
    The Stance GR+ 3-Way is our top of the line coilover. The GR+ 3-Way features 3-way adjustability, enabling the driver to fine tune low-speed and high-speed bump separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
    General Tech data on these coilovers for your Subaru the shock body is 53mm in diameter with a 47mm shock piston. All Stance coilovers are monotube for better damping control and anti-fatigue
    characteristics. For the Subaru Impreza application, being MacPherson on all four corners, they are inverted which gives the shocks better heat dissipation for high severity conditions, like at the track. Another benefit the Impreza applications have is that all four corners come with camber plates for increased camber adjustment. This is a very simple concept, but is something that is overlooked by most other coilover manufacturers. The standard spring rates are 8K/6K on the GR+/GR+ Pro,
    but for those looking for a stiffer spring rate to take advantage of R-Compound tires can get the SS-D which is valved for 11K/9K. We can also have custom valved coilovers made for custom spring rates.
    Retail: $2995.00
    On your Stance order have a Stance-USA T-Shirt on Me!!!
  2. ZenMotors
    ZenMotors Member
    BC Racing Coilovers!!!
    BC Racing is proud to provide coilovers that strike the best balance between performance and cost. We have designed all the most popular and essential features into our coilovers while keeping the end price down for the consumer. Whether you are cruising down the street, enjoying your favorite twisty mountain road or tearing up a race track we have a coilover system for you.
    BC Racing Coilover Specs
    General
    • Mono-tube shock design
    • 30 levels of damping force adjustment
    • Pillowball mounts and adjustable camber plates included*
    • Adjustable rear camber plates available
    • Separate Full length height adjustable
    • Inverted and Non-Inverted setups
    • One year warranty
    • Rebuildable *Fronts, where applicable
    Technical
    • Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
    • Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
    • Patented concave lower locking ring, to prevent unseating
    • Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
    • T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
    • Iron lower brackets on MacPherson struts to ensure rigidity
    • Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
    • High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
    • 2 step coating process utilizing nickel and chromium plating to prevent corrosion
    • Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation.
    • An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself.
    • Each BC damper is individually dyno tested before leaving the factory, making sure each damper is matched to within 5%, ensuring an equal balance in handling. OEM standards are 13% in comparison.
    BC BR Series:
    Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
    BC Ram Series:
    BC Racings Inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover setup we move the vital damper fluid away from detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The Inverted setup also handles high-g loads better and is much more durable under high stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
    BC ER Series:
    Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than a conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune their setup using the separate, 30-way, rebound and compression tuning dials.
  3. ZenMotors
    ZenMotors Member
    Bump for Specials!!!
  4. ZenMotors
    ZenMotors Member
    Weekend Bump!!!
  5. ZenMotors
    ZenMotors Member
    Shave time off your laps!!! Buy a suspension kit today!
  6. ZenMotors
    ZenMotors Member
    Buy a set of Coilovers get the labor for installation 15% off!!!
  7. ZenMotors
    ZenMotors Member
    Bump!!!
  8. ZenMotors
    ZenMotors Member
  9. ZenMotors
    ZenMotors Member
  10. ZenMotors
    ZenMotors Member
  11. ZenMotors
    ZenMotors Member
    bump!!!
  12. ZenMotors
    ZenMotors Member
    Bump!!!
  13. ZenMotors
    ZenMotors Member
    Bump!!!
  14. ZenMotors
    ZenMotors Member
    Bump!!!
  15. ZenMotors
    ZenMotors Member
    June Special - Buy a Coilover set and receive Additional discount on your Installation!
  16. Bug-Rex
    Bug-Rex Active Member
    Can you order Cobb sways for me?
  17. ZenMotors
    ZenMotors Member
  18. ZenMotors
    ZenMotors Member
  19. ZenMotors
    ZenMotors Member
    Bump for Serious deals!!!
  20. ZenMotors
    ZenMotors Member
    bump!!!
  21. ZenMotors
    ZenMotors Member
    Bump for Specials!
    Buy a set of Coilovers. Any coilover get them installed for $240.00
  22. ZenMotors
    ZenMotors Member
    Bump for Specials!
  23. ZenMotors
    ZenMotors Member
  24. ZenMotors
    ZenMotors Member
    Buy a set of Coilovers get major discount of your labor!
    Give us a call today!
  25. ZenMotors
    ZenMotors Member
    Order any Coilover kit and get it an amazing rate!
  26. ZenMotors
    ZenMotors Member
    Order a set of Coilovers today and get $100.00 off your normal Installation
  27. ZenMotors
    ZenMotors Member
  28. ZenMotors
    ZenMotors Member
    Order your set of Coilovers today, and Receive free Shipping!!!
  29. ZenMotors
    ZenMotors Member
  30. ZenMotors
    ZenMotors Member
  31. ZenMotors
    ZenMotors Member
    Bump for Zen!!!
  32. ZenMotors
    ZenMotors Member
    Bump for Zen!
  33. ZenMotors
    ZenMotors Member
    Buy from Zen! Great prices, with alway Great Service!!!
  34. ZenMotors
    ZenMotors Member
    Bump for Zen Motors!!!
  35. ZenMotors
    ZenMotors Member
  36. ZenMotors
    ZenMotors Member
    Bump for Zen!!!
  37. ZenMotors
    ZenMotors Member
    Bump for Zen!
  38. ZenMotors
    ZenMotors Member
    Bump for Zen!
  39. ZenMotors
    ZenMotors Member
    Bump for Zen!
  40. ZenMotors
    ZenMotors Member
    Order Now get Free Shipping!!!! Black Friday Sale all week long!!!
  41. ZenMotors
    ZenMotors Member
    Bump for Black Friday!!!!! Deals too good to be true!
