DBA Brake Rotors!!! DBA Standard Series Slotted Rotor ok cancel The Standard Series is DBA’s entry level enhanced performance rotor, offering improved braking straight out of the box. Available with slotting to improve pad bite and reduce brake fade. This also helps allow maximum cooling and provides an attractive, aggressive appearance. The Standard Series is the perfect replacement for performance conscious street motorists. DBA's Patented ‘Kangaroo Paw’ ventilation design is available on most popular DBA Street Series Rotors. * Directional slotted design (Left-hand and right-hand disc rotors) * Gun-metal grey paint provides better corrosion protection * Rapidly expels friction gases * Provides even pad wear and assists in minimising glazing of pad surfaces * Minimises brake fade * Ideal for towing and heavy loads Zen Price: $469.99 (Front & Rear) DBA 4000 Series ok cancel DBA's 4000-series is their mid-range enhanced performance rotor. It features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. The unique 6x6 Wiper Slot is designed to efficiently clear dust and debris while maintaining consistent friction and a cleaner disc surface. The 4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%. Designed for the performance street and motorsport enthusiast. Zen Price: $589.99 (Front & Rears) DBA 5000 Series ok cancel The DBA 5000 series is a direct replacement two-piece disc brake rotor, designed for drivers seeking performance braking. The DBA 5000 series disc rotors consists of two main components: the aluminum center hat and the cast iron disc rotor. These two components are bolted together with NAS (National Aerospace Standard) bolts and lock nuts, hence the term 'two-piece' rotor. The main advantage of a two-piece rotor (with aluminum hat), is the ability to allow the cast-iron disc rotor to expand and contract uniformly as the temperature rises and falls during brake application. The benefits of this is minimal distortion and warping of the cast-iron disc rotor. The Aluminum mounting center hat is made from super-light 6061-T6 Aluminium material, as used in aircraft structural design. The thermal conductivity and high strength of hat allows it to handle large temperature changes. The benfits of this is minimal distortion and warping of the cast-iron disc rotor. All DBA 5000 series rotors are slotted; slotting limits the possibility of glazing your brake pads and allows better 'pad-bite' under extreme braking conditions. Slotting constantly improved the disc pad friction face by wiping away the impurities and resins in the friction material. The DBA 5000 series rotors are manufactured with directional slotting, i.e. Left-Wheel disc slotting and Right-wheel disc slotting. Features: * Direct replacement rotors * Hats made from super-light 6061-T6 aircraft Aluminium material (reusable) * Replacement disc rotors available (without hat) * NAS (National Aerospace Standards) bolts and lock nuts * Thermal Stabillity Profiling (TSP) * Minimal bedding-in of rotors * DBA 5000 series slot design * Thermo-Graphic paint markings for temperature monitoring Zen Price: $679.99 (Fronts!) Techna-Fit SS Brake Lines Techna-Fit SS Brake Lines These stainless steel braided lines feature a heavy duty clear rubber coating on the outside to prevent chaffing. Stainless brake lines help reduce pedal "squish" that can be found under hard braking conditions and provide an additional degree of protection from the harsh environments of both the city streets and the racetrack. All Techna-Fit stainless brake lines are made to MVSS-1006 specifications and are fully DOT certified for road use. Zen Price: $98.99 Carbotech Brakes!!! We take you deeper into the corners & across the finish line first! When you want the control and modulation to take your track-bred car deep into the turns, you need unsurpassed Carbotech brake technology. Going deep before you brake allows you to stay on the accelerator longer going into the corner and even faster coming out. If you're a professional racer, or if you're taking your street car to the track for club events, Carbotech has the best braking solution. That's why we are becoming the #1 manufacturer of performance brake pads around the world with professional and club racers--everyone who demands the best. At Carbotech, we've been heavily involved in club and professional racing for more than 13 years. We know what you need to win.Smarter construction. Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors. Carbotech Performance Brakes utilize true race compounds that are "rotor friendly," eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long. Custom solutions. Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call and we can recommend the compounds that will be perfect for your front and rear pads and shoes, assuring that they perform together with optimum effectiveness. Give me a call for Quote on the application you are looking for! Street, Race, you name it!!! Do these products not interest you? Don't worry I carry many brands not posted above. Hawk, Stoptech, Powerslot, Stoptech, Ferodo, Goodridge, and More!!! Give me a call today!!!
