2011 sti
Discussion in 'Member Journals & Project Build Stories' started by stirhino, May 24, 2014.
  1. stirhino
    stirhino Member
    Well as most of you know I sold my built 04 STI that made 540AWHP about 2 years ago. I missed it so I bought a 2011 STI.
    UPDATED BUILD SPECS:
    Motor fully built by Ball Engine
    Outfront Motorsports closed deck block 99.75mm
    Torque plate honed
    Mahle forged 2618 pistons
    Manley turbo tuff I beam rods
    Clevite performance main and rod bearings
    OEM headgaskets and case seals
    ARP 625+ headstuds
    BC stage 2 cams
    BC springs and retainers
    Grimspeed lightweight crank pulley
    Group N motor mounts
    PT 6266 turbo with DEI titanium blanket
    Grimspeed EBCS
    Tial Q BOV
    Tial MVR EWG
    NGK 1 step colder spark plugs
    Rotated intake manifold powder coated candy apple red Grimmspeed phenolic 8mm spacers
    Valve covers powder coated candy apple red
    FMS FMIC with custom piping for rotated manifold
    TGV deletes
    Air pump delete
    KillerB oil pan
    KillerB oil pickup
    KillerB windage tray
    Crawford AOS
    Omni Power 4 bar MAP sensor
    Odyssey PC680 lightweight battery Cobb accessport V2 speed density tuned via DBW Motorsports 606.0 awhp and 540.6 awtq on Q16 on a Mustang dyno (md-awd-500)
    Fuel System:
    Walbro 460 fuel pump
    AEM fuel pressure regulator
    Perrin fuel rails and lines
    ID1300 injectors
    Drivetrain:
    Competition clutch stage 4
    Kartboy short shifter
    Group N transmission mount
    Perrin pitch stop
    Exhaust:
    GTSpec EL headers DEI titanium wrapped
    Custom 3" downpipe no cat
    Custom uppipe
    Magnaflow exhaust
    Suspension:
    Cusco strut tower bar
    ISC coilovers
    Perrin super steer kit
    Whiteline front and rear swaybars
    Whiteline steering rack bushing
    Interior:
    Status racing seat
    DEFI boost gauge
    DEFI oil pressure gauge
    AEM UEGO wideband
    TWM weighted shift knob
    OLD BUILD SPECS:
    Build specs are
    CP Pistons
    Manley turbo tuff rods
    king bearings
    ARP head studs
    BC stage 2 cams
    GS lightweight crank pulley
    PT 6266 turbo
    Tial Q BOV
    Tial 48mm wastegate
    Rotated intake
    FMIC
    TGV deletes
    Killer B oil pickup
    Walbro 460
    Perrin rails
    ID2000
    Comp stage 4 clutch
    kartboy short shifter
    Magnaflow exhaust
    custom DP and uppipe
    Cusco Strut bar
    ISC coil overs
    Perrin Super steer kit
    whiteline front and rear sways
    whiteline steering rack bushing
    car made 435AWHP on 93 at 21psi. Will get a retune soon.
    https://www.youtube.com/watch?v=hYQe_YRH8hg
  2. digitizedsoul
    so sick!
    i, for one, am glad you are back my friend
  3. superhawk28
    superhawk28 Member
    Is it on airbag suspension too? Really like the stance of that car.
  4. Holc13WRX
    Holc13WRX Supporting Member
    ISC coilovers...
  5. digitizedsoul
  6. stirhino
    stirhino Member
    No bags, just coil overs. I do like the stance also, thanks!
  7. stirhino
    stirhino Member
    Here are a few new pics.
  8. Holc13WRX
    damn. Engine bay looks awesome man. I'm sure cops will not hesitate to give you a speeding ticket when they see your license plate holder though haha.
  9. WRboXer
    WRboXer Active Member
    holy chit
  10. stirhino
    stirhino Member
    Well with my recent short block failure and new build is under way! As of now the car is still getting to and from work on 3 cylinders. :p
    Outfront Motorsports 2.5L closed deck block
    ARP 625+ head studs
    Cosworth 99.5mm Pistons Changed to Mahle 99.75mm pistons
    Cosworth Billet Crank changed to stock crank
    Cosworth Rods keeping the Manley I beams
    Everything else will most likely stay the same. I will be doing the short block swap once the fresh short block gets here from Outfront. Then it will be time for break in then off to TopSpeed for tuning. Will most likely tune for 93 and race gas. Most likely gonna stay away from E85 just due to the toll it puts on everything it comes in contact with.
  11. digitizedsoul
    Cosworth crank?
    Ballin???? :D
    I'm going to do the same, i'm going to get Doug to do a race gas tune for me, and pick up a couple jugs of C16 or Q16. That will be what I run at the half mile next year.
  12. stirhino
    stirhino Member
    Got a pretty good deal (I guess) so I pulled the trigger. Was just gonna reuse my rotating assembly but the new stuff just made more sense then I'll sell my stuff to recoupe some of the funds. Now I can continue to drive my car to and from work while waiting for the short block to get done.
  13. Justin V
    Justin V Member
    Watch your oil like a hawk and I hope you don't mess up your heads.
    if a bearing spins add another $2000 at least to the cost
    you may get hot spots in that cylinder anyways from it not having compression and getting a good burn. or a carbon chunk in between a valve and seat and burn a valve.
    I guess you gotta do what you gotta do but I'd quit while you are ahead.
  14. digitizedsoul
    If you want to drive my VW Passat for a couple weeks lemme know.
  15. stirhino
    stirhino Member
    Wow! That is awesome. I'm gonna try to borrow a vehicle from someone I know buy if not I may take you up on that. I only drive 12 miles to work so it's not a lot of driving.
  16. stirhino
    stirhino Member
    And it begins....
    Just want to give a HUGE thanks to digitizedsoul, without his help I don't know what I'd do or how to get this started!
  17. ChrisW
    ChrisW Member
    That stand and hoist look oddly familiar ;) I'm also in Gwinnett, let me know if you need a hand.
  18. kaylee
    kaylee New Member
    Happy mechanicing! :cool:
    Just remember the second definition of an engine hoist: "tool also used to test the tensile strength of ground straps, electrical harnesses, and piping."
  19. ChrisW
    ChrisW Member
    I've destroyed more than I care to admit this way
  20. kaylee
    kaylee New Member
    Just saying "break a leg" in car language. Wish you the best on the build.
  21. digitizedsoul
    LOL i broke the same ground strap (bottom one) TWICE.
    Gave myself the o'l facepalm for that one.
    Hope the Passat does good for you Ryan, God knows it needs a bath inside and out, and pretty sure the turbo is shot but it beats walking!!!
  22. zugu
    zugu New Member
    I'm in Gwinnett as well, still new to Subarus, but I know my way around tools if you do need help.
  23. Justin V
    Justin V Member
    Scientific fact: Only a given number of subaru's can be on the road at one time. One must die for another to have life.
    Mine's alive.
    Good luck, I'm praying I don't have a fire from the oil leak.
  24. kaylee
    kaylee New Member
    Hey, fellow Gwinnetian!
  25. digitizedsoul
    When things settle down after my wife goes back to work from maternity leave, i'm going to see what days i'm left with and put together a gwinnett meet for wrxatlanta somewhere local to peachtree corners
  26. stirhino
    stirhino Member
    Well motor is out. Thanks everyone for offering to help, but I got it all done by myself. :)
    Now I just got to break it down tomorrow.
  27. stirhino
    stirhino Member
    Well here is the damage on #2 and #4
    These are from #2 where leak down was 90%
    Here is #4 where compression was a little low at 135
  28. digitizedsoul
    Looks like some serious ovaling happened there man, and obviously the cracked stock sleeve which could also have been cause by ovaling.
    This is why folks pin their blocks I guess or go closed deck.
  29. b reel
    Extreme combustion chamber heat, high cylinder pressures and detonation. It's clearly obvious with the amount of pitting at the top of the cylinder wall
  30. stirhino
    stirhino Member
    Keep in mind I drove the car for a few weeks daily after this happen. So I think a lot of that crap at the top of the cylinder is from that. Because the other side of the block doesn't look like that
  31. superhawk28
    superhawk28 Member
    Hmmmm the fact that both cylinders are damaged makes me question if it was a fuel delivery issue on that side?
  32. stirhino
    stirhino Member
    All parts have been dropped off at Ball Racing! :)
    #2 piston was shot from ovaling the cylinder.
  33. digitizedsoul
    Called it.
  34. Justin V
    Justin V Member
    So just to recap.
    Closed deck case from outfront, but Ball is assembling the shortblock?
    I know you switched studs to 625+
    Still all the fancy cossy stuff?
  35. stirhino
    stirhino Member
    Yes closed deck from outfront. 625+ studs mainly to save a few bucks plus 1/2" are on back order. Deal fell through on cossy stuff you could say. Lol.
    Will be
    Outfront closed deck block
    625+ studs
    Mahle 99.75 pistons
    Sti crank
    Manley I beam rods
  36. Justin V
    Justin V Member
    What alloy mahle's?
    most people use mahle's for the 4032 which would scare the piss out of me with your setup?
    is this a halloween prank?
    If you pull this off it will be impressive, but James and I are both using 2618 for our higher power setups. I know the Cosworth stuff was magic and walked the line.
  37. stirhino
    stirhino Member
    They will be the powerpak plus which is the 2618's dont think regular powerpak (4032) pistons can handle the power level I'll be at.
  38. Justin V
    Justin V Member
    good sounds like a nice setup, we'll have to split a barrel of c16 and go make some 30+psi passes.
  39. stirhino
    stirhino Member
    Yeah between me, you and James we can split a barrel
  40. superhawk28
    superhawk28 Member
    Do q16 rather than c16. Mmmmm that peppermint smell.
  41. b reel
    Q16 with lead bad, VPimport good...
  42. superhawk28
    superhawk28 Member
    That's what I was referring to. VPimport. My car loved that stuff!
  43. digitizedsoul
    yeah it's like 10$ a gallon lol
  44. stirhino
    stirhino Member
    Well just a quick update. Block will be leaving Outfront in Cali. on Monday (Nov.3) then it will go to Ball Racing to get bored, honed, and assembled.
    Also going on it are the Killer B V2 oil pan, Windage tray and Tomei timing belt guide.
    Should have it back on the road very shortly
  45. superhawk28
    superhawk28 Member
    Why doesn't Outfront do the boring and all themselves?
  46. stirhino
    stirhino Member
    They do, but I decided to get all the work done at Ball to help support a local company and so I didn't have to ship my stuff to Cali.
  47. digitizedsoul
    They won't make you regret that decision Ryan. Love the ball's.
    lol
  48. stirhino
    stirhino Member
    I'm hoping Ball will be done with the build this week. I dropped the closed deck block off to them last week.
  49. digitizedsoul
    Can't wait to see this done!!!!!
    I might go drop by today and see them. It's been a while since I saw muh ball's
  50. stirhino
    stirhino Member
    Lol! If you stop by take a picture for me!
