93gcsedan's 95 coupe!
Discussion in 'Member Journals & Project Build Stories' started by Cory, Dec 12, 2009.
  1. Cory
    Cory Member
    I picked up my stage 3 kevlar clutch yesterday. $340 out the door is pretty good to me. That included all the bearings and the flywheel resurfaced.
  2. UpSideDownDesi
    UpSideDownDesi Active Member
    PMed you about the wastegate you are looking for.
  3. Cory
    Cory Member
    PM received. $300 is a little rich for my blood.
    Decided to wrinkle red the valve covers. Thinks are getting closer to a "finish" with the engine.
  4. Sparta
    Looks good!
  5. Cory
    Cory Member
    Thanks.
  6. Cory
    Cory Member
    I am also 98% done with my parallel fuel line mod. I used high pressure fuel line with brass tee fittings. I cut the stock line and flared it so the lines will not pop off. You can kind of see it in the pic above.
  7. Cory
    Cory Member
  8. Cory
    Cory Member
    wow no comments?
  9. Sparta
    Looks badass man! Is that an NA intake manifold or a jdm sti one? Hopefully i can strt on a build like this soon
  10. Cory
    Cory Member
    Its the jdm wrx one painted wrinkle red. The wrx and the sti have the same manifold minus the paint. I figured since I am running an ej257 short block I had the right to paint it. I also love the fact the runners are longer and the plenum is larger than the 02+ wrx manifolds so the engine should make more power. :)
  11. Sparta
    Good to know, so whats left?
  12. Cory
    Cory Member
    I need to get a down pipe made, get a hydrolic petal assembly and clutch master cylinder, and the wiring harness merged. It should be done in the beginning of October as I will be out of town for two weeks.
  13. Cory
    Cory Member
    Finally got my car running.i am still running the 1997 WRX heads but am running a rebuilt ej205 short block that I did with STI rods, King main and rod race bearings, recommended by the guys at Allpro, and a shimmed 10mm oil pump.
    Hear is one of the first start up videos of my car.
    [youtube]uVBKNSki7rs[/youtube]
    When the camera is moved towards the back of the engine you hear a loud ticking noise. That is the pressure plate contacting the clutch fork. Don't worry that problem is fixed. With a huge thanks to Brandon at Allpro for all the help.
  14. Cory
    Cory Member
    Oh yeah with the new short block set up, the compression ratio is right around and maybe a little above 9:1
  15. kohlby777
    kohlby777 Member
    I can't wait to see it on the road man
  16. whitepony22
    whitepony22 Member
    I remember talking to you and seeing this from SouthernFresh. Can't wait to see this thing up and running.
  17. Cory
    Cory Member
    Yeah its been a long time coming.
  18. Cory
    Cory Member
    I am going to paint my car so I need paint suggestions. I really like white because my first Impreza was white so I have an attachment to that color. But I am open to other colors other than world rally blue and any red. So lets here those suggestions...
  19. liltoua
    liltoua Member
    I say red only because there are little to no red 2.5rs around. If no red then I would just go with white.
  20. Banana
    Banana Member
    Satin White Pearl
  21. osborne519
    osborne519 Member
    u need to hurry ur ass back from maryland so we can finish the car and actually drive it i already took 2 days off of work
  22. Cory
    Cory Member
    I know man I am definitely looking forward to driving the car since parking it in the garage in 2009!
  23. b reel
    I say this every time I walk past my car
  24. Cory
    Cory Member
    The satisfaction of starting my first turbo car that I built from the ground up with my own two hands was just amazing! I am so ready to drive that car out of the garage under its own power!
  25. Cory
    Cory Member
    800cc injectors- ordered
    Fuel injector adapters (to fit in my factory fuel rails)- ordered
    Walbro 255LPH - ordered
    Grimmspeed Master cylinder brace- ordered
    Goodridge Stainless Steel brake lines- ordered
    Thank god for tax returns :)
  26. Cory
    Cory Member
    Three LSDs' are gonna be epic.
  27. Cory
    Cory Member
    Gauge cluster no lighting up and no gauges reading...such is life.
