Alex's 2004.5 STi! -- 12/15: S204 Performance Damper Ordered! :p
Discussion in 'Member Journals & Project Build Stories' started by Alex, Mar 22, 2006.
  1. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    Was able to install the oil pressure sensor before 420s party last weekend :)
    Extension + 8mm hex to remove OEM gallery plug
    Extension + 17mm socket to remove OEM plug
    OEM plug on left, Defi sensor in the middle and OEM gallery sensor on right
    I used my magnetic wand to actually place the OEM gallery sensor, and then a 17mm socket + extension to screw it in
    Now maybe Im just not that good, but I wasnt able to thread the defi sensor into the plug with the TMIC still on. With it removed it was substantially easier and I had the help of Ankur's magical fingers...
    Used a crows foot to tighten it down
    Plug it in, ran through passenger side firewall grommet into controller (mounted in glove box)
    3 piggies at home
  2. mmtasty
    mmtasty Active Member
    Apr 21, 2006
    1,441
    0
    Dammit Blindfold! I keep getting finger prints on my screen trying to squish that bug in your sig.
    That is all.
  3. Cool_____
    Sep 5, 2005
    7,338
    0
    Looks SICK! I'm jealous!
  4. AtlxPat
    AtlxPat Active Member
    Dec 9, 2006
    1,328
    0
    im liking the red
  5. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Just got off the phone with Chris @ WC Lathewerks and I should have my new knob next week. Ive always been interested in his products, as quality is rated top notch continuously on IWSTi and NASIOC.
    What's cool about WC Lathewerks?
    Every knob is made on a hand-crank machining lathe with no computerized controls. This means each piece is unique, made one at a time, and has a bit of character that mass-produced pieces cannot offer. Each knob is internally threaded with an M12x1.25 tap and will screw right onto the shift lever.
    Why a Lathewerks knob?
    The knobs (excluding aluminum...duh) are made of a plastic material called Acetal Copolymer. Acetal Copolymer is a hard plastic which does not suffer the same heat characteristics as metals. This means you can touch it all year long without the need for gloves. For reference, it will stay about the same temperature as the steering wheel at all times. This is a truly impressive material which results in a shift knob that is just the right weight, while transmitting high amounts of feedback to the driver through the shift lever.
    Dimensions, etc
    • 2.0" Diameter for comfortable size
    • 1.8" Height to sit slightly lower than the stock knob
    • 105 grams for more feedback than standard knob and a solid feel!
    • M12x1.25 direct internal thread for easy screw-on installation
    • Recess in bottom for 6-speed reverse ring to give stock appearance
    Brass Insert, Why?
    The insert adds 25 grams to the mass of the knob, while also providing stronger metal threads inside (a la it will not strip like plastic threading found on most knobs). Additionally, the insert provides the weight of a metal knob with the comfort of the copolymer plastic.
    I also had 2 small grooves added to the bottom for that little bit of bling. Similar to this photo below...
    Updates to come once the knob arrives. I realize its a bit nutty to be excited about a shift knob but the quality and attention to detail of this one...excites me :ddirty:
  6. Matt
    Matt Think before you post
    Staff Member Supporting Member
    Oct 8, 2003
    8,409
    23
    This is the same knob I've been rocking for the past 3 months. It's AWESOME!!
    *well, not the 6spd knob, but the 5spd knob ;) *
  7. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    I thought you had this one
  8. Matt
    Oct 8, 2003
    8,409
    23
    Hence my little star....what I was getting at was the company you went with ;)
  9. rexrocker
    Oct 8, 2004
    1,558
    0
    Nice dude! :bigthumb:
  10. Weapon
    Weapon 90lbs of dynamite
    Supporting Member
    Jan 29, 2005
    6,875
    0
    looks sweet dude
  11. Jewels450
    Jewels450 Member
    Jul 31, 2007
    775
    0
  12. GTscoob
    Jul 30, 2004
    4,813
    1
    I like the look of those knobs. What color are you getting?
  13. Scotty B
    Scotty B Member
    Aug 8, 2007
    155
    0
    excellent, i love mine. they are great people to work with. it's also a very comfortable knob, never gets too cold or hot.
  14. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Black
  15. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    #665 Alex, Oct 4, 2007
  16. schneid
    schneid Member
    Feb 2, 2006
    616
    0
    looks great Alex...I think the white knob could look pimp...hmmmm
  17. savsuby
    savsuby Member
    Apr 10, 2006
    487
    0
    lookin good Alex
  18. wrxin8or
    wrxin8or Mullitt
    Staff Member
    Feb 7, 2005
    4,190
    1
  19. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Well I threw on the WRX fog lamp cover to see how the car would look if I ran ducting. While I am not one for asymmetrical things, I believe I could live with this...An alternative of course would be to do a single xenon fog light setup in an effort to throw even more light out on the road ;)
    Now, I wonder why my steering wheel would be out of the car...Humph, any guesses? :D ( Hint: http://www.wrxatlanta.com/forums/showthread.php?t=17695 )
    Here are two snaps of the airbag, in case you have never had a chance to look at one up close.
  20. XanRules
    XanRules Active Member
    Jun 4, 2007
    1,496
    0
  21. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    I have always been rather disappointed with Subaru's material choice on our door cards. Last week we junked the pajama pants felt and replaced it with a near perfect factory match perforated blue Alcantara. The cards are 1/3 done, if you will. The top portion will be wrapped in black Alcantara soon, as well as the armrest. Ultimately, the upper portion of the car will be done entirely in black Alcantara. This is the reason for wrapping the upper portion of the doors. This should create a seamless transition from the doors to the pillars to the headliner.
    These are 04 door cards, the 05 cards are different as I am sure you all know.
    ak
  22. oneiguy
    oneiguy Active Member
    Apr 18, 2007
    1,162
    0
    Looks good dude. Tempting...
  23. jt money
    jt money 350hp mmm mmm Good!
    Supporting Member
    Apr 16, 2005
    4,107
    0
    cards look great bro! on the fog light covers if you go with ran ducting you should get rid of the sti sticker and make it plain. just say no to the single fog light! ;)
  24. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Good point :)
  25. Sparta
    May 2, 2007
    3,693
    12
    Alex, do you want a wagon to play around with? hehe, I'm loving the alcantara
  26. scooby_snacks
    scooby_snacks Active Member
    Feb 8, 2006
    930
    0
    I'm up for giving you my miata boot/whatever you want if you want to experiment with anything. I need to get me a new shift nob too, the stock miata one feels horrible.
  27. dontcallitarex
    dontcallitarex Active Member
    Sep 23, 2007
    1,443
    0
    That looks great! It's cool how it like, exactly matched to the paint. Very nice, as always, Alex.
  28. Cool_____
    Sep 5, 2005
    7,338
    0
    As always 10th Street parts are top notch. My headlights are leaving SC in a few hours ;)
  29. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Cannot wait for the next free minute to do the rear seats too :) I doubt that minute will be here for a while though :cool:
  30. Batlground
    Batlground Active Member
    Dec 21, 2004
    923
    0
    I'm looking forward to seeing the Shop STI with a Black interior.
  31. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Im looking forward to seeing my crinkle red AOS ;D
  32. Batlground
    Dec 21, 2004
    923
    0
    Speaking of which, when are you going to be at your shop again. I may get you go drop off your car so I can install your AOS.
    Matt
  33. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    I am there everyday :) AND I need an oil change haha. How convenient :ddirty:
  34. slowwrx
    Supporting Member
    Mar 8, 2005
    4,343
    1
    How about Tuesday next week.
  35. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Shouldnt be a problem, I'll be in touch my good man.
  36. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    So there's something new on the way. They'll be here friday :)
    Hint: 4 separate boxes.
  37. dontcallitarex
    Sep 23, 2007
    1,443
    0
    I know what it is....you whore. :)
  38. Deke
    Deke Active Member
    Jan 28, 2006
    2,694
    0
    Japanese stuffed animal key chains to hang off of your tow hook?
  39. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    kitty no legs! meow meWOW
  40. blindfold
    blindfold Active Member
    Aug 29, 2006
    1,596
    0
    should be pretty cool
  41. GTscoob
    Jul 30, 2004
    4,813
    1
    Making your own mudflaps out of trucknuts?
    I think one mounted behind each tire would stop a little bit of the money shot from each puddle from giving the side of your car a nice pearl necklace.
  42. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    :werd:
  43. XanRules
    Jun 4, 2007
    1,496
    0
    oh god. Someone do that.
  44. Cool_____
    Sep 5, 2005
    7,338
    0
    4 packages? Hrrrmmm how big are said packages?
  45. Sparta
    May 2, 2007
    3,693
    12
    Jdm gold wheels?
  46. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Wonder what these could be...
    ..and no, I am not keeping them white :D
  47. XanRules
    Jun 4, 2007
    1,496
    0
    Well they're white...they're wheels...they're made in Japan...they're SSR...
  48. dontcallitarex
    Sep 23, 2007
    1,443
    0
    I dunno...you should mount them white just to see...might look pretty cool.
  49. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    blue + white = civic.
  50. bsigari62
    bsigari62 Member
    Sep 9, 2007
    172
    0
    yeah keep them white to see
