Building my EJ257 longblock....many questions and opinions
Discussion in 'Modifications & DIY how-to' started by Cool_____, Apr 21, 2008.
  1. Batlground
    Batlground Active Member
    Dec 21, 2004
    923
    0
    I just ran it through an online compression ratio calculator which could be wrong.
  2. Batlground
    Dec 21, 2004
    923
    0
    Its not below 9 to 1 for sure.
  3. Cool_____
    Sep 5, 2005
    7,338
    0
  4. Batlground
    Dec 21, 2004
    923
    0
    Thats pretty close to right actually, once I changed my numbers to reflect it not being a zero deck motor, and I put in the head gasket thickness in MM instead of inches....lol
    I actually get 8.8 to 1
  5. Cool_____
    Sep 5, 2005
    7,338
    0
    WJM says the same thing. I think this is a very desirable ratio since I can then use the Stock STi head gaskets.
  6. WJM
    Dec 12, 2004
    5,401
    0
    That chart is off. Stock compression for 04~06 STi is 8.2:1 according to the FSM. However, if all those measurements are correct, then ok. I wont argue.
    However, the piston to deck clearance on a stock EJ257 is 0.50MM. I measured it 5 separate times to be sure...meaning I made sure it was at TDC, measured twice, then re-TDC'd it and measured twice...etc. So really I measured it 10 times. :lol:
    Last time I checked an EJ205, it was nearly 0.00mm. I know the EJ25D, 1997~1999, the pistons end up ABOVE the deck by .5~.7 MM. You HAVE to use the AA610 gasket or the pistons hit the head.
  7. Cool_____
    Sep 5, 2005
    7,338
    0
    Jeff's differences could very easily be the tools you are using I mean .38 mm is TINY TINY TINY and hard to measure. That being said it's obviously very close to the real answer though. Did you read through what Jeff said on Nasioc? It's a very good read.
    I think the 8.8:1 CR is right though......it's so close to the charts, to Matt's measurements, and to your measuresments that it's a safe bet to say that it is definately going to be under 9:1.
  8. WJM
    Dec 12, 2004
    5,401
    0
    .38mm is not hard to measure or see. A simple digital caliper set is all you need for that.
    Or, clearance. A simple feeler gauge is easy to use...
  9. Cool_____
    Sep 5, 2005
    7,338
    0
    Oh well it's probably user error but it's still close enough to say that the CR will indeed be 8.8:1ish....right?
  10. WJM
    Dec 12, 2004
    5,401
    0
    I'd say so.
  11. Batlground
    Dec 21, 2004
    923
    0
    Yep, I would say you are going to be very close to 8.8
  12. Cool_____
    Sep 5, 2005
    7,338
    0
    Then it's official. The STi head will be pulled off the block and posted for sale.
    I will get the WRX heads from Mike and will go that route.
  13. WJM
    Dec 12, 2004
    5,401
    0
  14. Cool_____
    Sep 5, 2005
    7,338
    0
    It makes more sense and is more budget oriented. I mean I'm only gonna push 450-480 hp daily on this thing if even that much on pump/meth. No sense building the daylights out of the engine when I won't be pushing it in the least bit.
  15. crashtke
    crashtke Member
    Supporting Member
    Jul 28, 2006
    1,816
    0
    I think you will love it. Bumped compression, bigger turbo, more displacement...should be great. And you can always go the other route with AVCS and hydra if you win the lottery and have cash to burn.
  16. Cool_____
    Sep 5, 2005
    7,338
    0
    Yeah it's just better and AVCS really has nothing to do with power (I can debate that but the end result it really doesn't). If the car drives like my 18g on my 2.0L now then I am A-OK with that! Matt told me Dan's Sti with GT35R feels just like a 18g'd 2.0L. Scott has said the same about customers of his.
