Built motor guys chime in
Discussion in 'Modifications & DIY how-to' started by Cool_____, Jun 29, 2009.
  1. Mike@TTR
    Mike@TTR Active Member
    Jan 12, 2009
    1,329
    0
  2. Berzerklo
    Berzerklo Active Member
    May 21, 2007
    961
    0
    "Washing the cylinders down" - What does that mean? Is it unburnt fuel cooling the cylinders walls irregularly or something?
  3. integroid
    Supporting Member
    Dec 28, 2004
    3,084
    0
    "If the increased quantity of fuel is great enough, it can "wash" the film of oil from the cylinder walls, prior to ignition. This leaves ring-to-cylinder metal on metal, bad business."
    Also, too much unburnt fuel can get past the rings and mix with your oil. Gas is not a very good lubricant so that would be another bad side effect.
