Buyin' a new car - from the inside out
Discussion in 'Member Journals & Project Build Stories' started by Dacula Dean, Jun 14, 2006.
  1. Dacula Dean
    Dacula Dean Member
    May 15, 2006
    287
    0
    New brake pads
    Installed StopTech Street Tuner pads this weekend, and replaced the rotors. The Carbotechs had worn the old rotors too deeply. 91442 miles.
  2. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    Thank's for your quarterly check in Dean :)
    Let us know how you like the new pads. I have been talking with Ken @ KNS about the Stoptech pads as I'm after something similar to HP+ feel with a tad bit less noise :)
  3. Dacula Dean
    Dacula Dean Member
    May 15, 2006
    287
    0
    I'm smiling. I thought it had been more than three months since my last check in.
    First impression of the Stoptech pads is that they grab more at low speed and low pedal pressure than did the Carbotechs. Probably more so than stock or Hawk HPS, too, but my memory for these things isn't consistent. After that initial grab, then braking is proportional to pedal pressure.
    The boxes that they came in claimed no need for bed-in. Nonetheless, I intend to do some bed-in exercises. Can't hurt. Then, I'll try to give another report.
  4. Dacula Dean
    Dacula Dean Member
    May 15, 2006
    287
    0
    Sigh. It's been more than a quarter since my last check-in.
    At 95K miles, I get a new noise in the front left. It doesn't happen when the car is absolutely cold; I need to drive for 10 minutes before it starts. It's a squeeky-grindy noise, and it sounds like it's coming from the wheel - perhaps the hub.
    Continuing my critique of the StopTech pads - they're still very grabby on initial bite. With more pressure, the braking is very confident and consistent. My only complaint is that initial bite.
    I've added 17" Rota G-Force wheels in gold. Hoping to clean up the old stockers and offer them for sale.
  5. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Have you been under the car to see if there are any tears in the CV boot or anything of the nature?
    #55 Alex, Dec 24, 2010
  6. Dacula Dean
    Dacula Dean Member
    May 15, 2006
    287
    0
    The squeaky-grindy noise was my front left wheel bearing. Had to replace the hub and the bearing. Ka-Ching!
  7. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    Did you just replace the one or did you decide to upgrade all four?
  8. Dacula Dean
    Dacula Dean Member
    May 15, 2006
    287
    0
    I only replaced the one. I asked the tech whether this was an indication of a trend, and he couldn't say "yes." He said he'd seen one corner go twice before the other side went bad once. He did take a listen to the other side and didn't hear a reason to be concerned.
    But now I hear sounds when turning left that I don't hear when turning right. And the sound is in the right rear when I'm turning left. Front left first, the right rear? We engineers see patterns everywhere. I'm a cheap guy, but I would have been less jumpy if I had just replace the four.
    FWIW, I have evidence that something is outta whack in the front left. A stock alignment is no longer available on my front left - they can't get the camber to as few (negative) degrees as stock calls for. Now, it isn't outrageous. If I always went for a "track and autocross" camber, I would never know that there was an issue. But, my life has been boring recently, so I've gone for the stock and they couldn't do it. Something bent.
    Every couple of months, I think of replacing the car. But, there's nothing like it. My wife doesn't want to try to climb out of Lotus Elise or Exige, I don't want to pay for a Porsche, and the Bimmers I'd want are too costly, too. Then, I take the beast to the car wash and realize it really is a lovable lump. Maybe, when my daughter leaves home, I'll put a roll cage in it to tighten it up and ... whatever.
  9. Dacula Dean
    Dacula Dean Member
    May 15, 2006
    287
    0
    Wow. This is a little frightening. My last post was exactly a year ago. And this thread is turning into something that resembles an endurance log. I am now up to roughly ten years and 108,000 miles on this WRX. A couple of weeks ago the car was in for new valve cover gaskets and a new oil cooler seal. Now the engine revs when I put the foot down and the turbo spins up in fourth and fifth gears - I'm guessing it's time for a new clutch.
  10. Dacula Dean
    Dacula Dean Member
    May 15, 2006
    287
    0
    Yup. New clutch.
