Isn't it time...
Discussion in 'Allpro Subie Service & Performance' started by orndog, Feb 27, 2015.
  1. orndog
    orndog Member
    ...for more specials? Like, I dunno, a 30k service special sometime in the next 3k mile.... errr I mean months? :sx:
  2. J_P
    Supporting members get 10% off.
  3. Trancetto
    3k months.....what would the dress say to that.
  4. orndog
    orndog Member
    Oh lord, not the dress...
  5. RSConvert
    We can do that for you. Just give us a call.
  6. orndog
    orndog Member
    Will do!
    This is what SoA lists:
    30,000 miles
    Inspect drive belt(s) [except camshaft]
    Replace engine oil
    Replace engine oil filter
    Replace air cleaner element
    Inspect transmission/differential (front & rear) lubricants (gear oil)
    Inspect automatic transmission fluid
    Replace brake fluid
    Inspect disc brake pads and discs, front and rear axle boots and axle shaft joint portions
    Inspect brake linings and drums
    Perform inspect brake lines and check operation of parking and service brake system
    Inspect clutch operation
    Inspect steering and suspension
    Perform rotate and inspect tires
    Recommended Inspection fuel systems, lines and connections
    Inspect engine coolant systems, hoses and connections
    Replace a/c filter
    Inspect cvt fluid
    I do most regular service myself usually, so the air filter is good lol. But so you know I'll be wanting a price for going ahead and doing the diff and CVT fluids as well. I'm not sure which version of the CVT I have, hopefully it's not the one that will give me problems.
    Also, it's been using oil lately, and I know there's a TSB regarding the rings, are you guys familiar with that?
  7. Sparta
    I thought they recently advertised a 30k special?
