Liltoua's Little Black Beast
Discussion in 'Member Journals & Project Build Stories' started by liltoua, Feb 23, 2011.
  1. Matt
    they almost look like a/c hard lines to me...not sure though.
  2. liltoua
    liltoua Member
    Pulling the motor today hopefully. Waiting on a friend for the hoist and it should be coming out.
  3. b reel
    from top left clockwise, coolant line to the turbo res, line to the TB, line to heater core, the bottom two go to the water pump.
  4. Sparta
    Yes those go under the manifold lol
  5. b reel
    and behind the timing covers
  6. liltoua
    liltoua Member
    Yes! Thanks guys! After you guys posted that I took off the manifold and figured out why there was two loose bolts on my coolant crossover pipe. HAHA. Bolted everything down and it's starting to look more like a motor =). Thanks for the help guys! I can always count of WRXATL
  7. liltoua
    liltoua Member
    Update:
    Thanks to B reel and Sparta for pointing me in the right direction. Got the coolant lines bolted in and everything assembled.
    Also I didn't have my inlet during my assemble the first around time, so I didn't get the chance to put the inlet on before putting the intake manifold on. So this time around I had my inlet and slapped it on before I assembled everything for the second time.
    I also did a leakdown test, but I think I did it wrong. I set my compressor to 100 PSI and I opened up the leak tester, but I don't think I ran enough pressure. I also wasn't sure if I did timing right so wasn't sure if TDC was really TDC HAHA. My friend that helped me said that my timing was good, but when I looked at it, it seems like I was off by one tooth. I'll take a picture and let you guys determine it. Here is a SHORT clip of one of the test. They were all pretty consistent and stayed in the green. I had one cylinder that was in the yellow "set", but then again I might have done it all wrong.
    [youtube]M-EcQymn1tc[/youtube]
  8. b reel
    did you put some oil in the plug hole before you pressurized the cylinder?
  9. liltoua
    liltoua Member
    I didn't :| , I herd about that. Should I have done it?
  10. b reel
    yeah because it will give you a better seal on the rings. It doesn't take much
  11. b reel
    low on cylinder 4? from front of motor back right cylinder
  12. liltoua
    liltoua Member
    Cool, since the motor is still out, I'll hook it up again and run it again with some oil in there and see the outcomes of it.
  13. Cool_____
    Turn crank until everything hits the timing marks. Take pic of each mark on the cam gears and the crank. I'll tell ya (or someone else) if you are in time or not.
  14. liltoua
    liltoua Member
    I don't think I was low on any cylinders. I was watching a video of a guy doing it on youtube, he said to run the gauge to 14.5 psi. Don't know if that's the right pressure to run but I did it and they all came out decent.
    Yea I'm gonna do that for you guys and see if I'm dead on with timing. That's the last thing I want to screw up on period lol. I do not want to pull out this motor again unless I'm upgrading.
  15. liltoua
    liltoua Member
    Just making sure that it's at TDC and if anything I'm worried about my driver side. Kinda hard to read and lineup, but is this correct timing?
    This one in particular I think I'm off by one tooth
  16. Cool_____
    Yup you are definately out of timing
  17. Cool_____
    And another way to check that you are TDC is take cylinder 1 and put a screwdriver in the spark plug hole. When the piston is all the way up top you are at TDC.
  18. liltoua
    liltoua Member
    Yea I was afraid that I would be off. That would have had effects on my leak down test right?
  19. Cool_____
    It would affect the leakdown but why are you worried about that right now?
  20. liltoua
    liltoua Member
    I'm not, just wondering if it would haha. Don't worry my timing is my first priority right now. I gotta take off the tensioner and compress it and redo it and I'll take more pictures just to verify it with you guys
  21. Cool_____
    Here's something I've had to do....you think it through. The pass side isn't gonna change. But walk yourself through what happens when you put tension on the driver's side. The tensioner will pull the drivers side cams therefore pulling them out one tooth. I have had to put the two driver's cams off one tooth so that when the tensioner was released, it pulled the drivers side into timing. It depends on the belt. When I used an aftermarket belt this was the case. OEM belt I've never had that issue.
    That make sense? You may want to get someone very experienced with it to help ya.
  22. liltoua
    liltoua Member
    Yea that makes perfect sense, and that's probably why I was off timing when I did this(using gates timing belt). Yea when my friend and I were doing it on my N/A motor with an OEM belt we didn't have this issue like you said with an OEM timing belt. I'll play around with it, I'm getting my friend to help me so it will be easier with two people on it.
  23. Cool_____
    My Gate's belt did the exact same thing. It was a little longer than stock to be honest. I threw it away and went with the OEM belt......zero issue then. The gates belt made the car like half a tooth off.
  24. liltoua
    liltoua Member
    If I can't get it to work then I'll just invest in an OEM one. It's just I already have it, why not use it LOL. If it's not worth the troubles then I'll just opt for an OEM one, depending on how much it cost :eek3:
  25. Cool_____
    $100. There are other reports of Gates belts being slightly too long. I'm not the only one.
  26. liltoua
    liltoua Member
    I know it's a crappy picture, but is there a way to confirm if this is a 04 STI steering rack?
  27. Matt
    fail.
  28. Cool_____
    Can't link straight to your Yahoo Mail dude.
  29. liltoua
    liltoua Member
    BAHAHA! Damn I thought that it would work like FB use to work.
  30. Matt
    facebook still works like it used to. you just have to hit F5 to refresh the image to get it to a copy-able image.
  31. liltoua
    liltoua Member
    That's good to know haha. Anyways a guy is selling this and I'm not sure if it's an STI one or not, and apparently the 04 STI are the only known steering rack that will work with my car with a mod to the steering column link.
  32. Matt
    I was told that the STi rack wouldn't work without extensive work...at least by itself.
  33. b reel
    with one rod missing and another bent I'd be worried the rest of it is junk.
  34. pEd
    ^^ Truf
  35. Cool_____
    That steering rack is trashed.
  36. liltoua
    liltoua Member
    Yea I just saw that, Looks like I'll just use my old one (-_-). I really want to upgrade my steering rack because it's developing a small leak....and steering rack leak is not good.
  37. Cool_____
    Get a Quick Rack :) I know they are expensive :(
  38. liltoua
    liltoua Member
    HAHA I've been looking at those! I would love to have one of those, but it just doesn't seem practical for a DD. Imagine letting someone driving your car with a Quick Rack that has no idea about it LMAO.
  39. liltoua
    liltoua Member
    Pulled the motor out! It's so much easier with two people.. My skinny ass alone on it was pretty damn hard LOL.
    Another question for you guys. I pulled the flywheel off and I can see very thin hairline cracks in them. I herd that I can get the flywheel machined (which I'm gonna do regardless) it may fix the problem. Should I go ahead and replace it, or just machine it and hope the hairline cracks go away?
  40. superdoughboy4
    Might as well upgrade while everything is out.
  41. b reel
    a machine shop will be able to tell if good or bad.
  42. liltoua
    liltoua Member
    Any recommendations on a good machine shop? Preferably near Gwinnett Area, I'm willing to make a drive if it's worth it. How much an I looking at? $40?
  43. yerrow
    yerrow Active Member
    Ball is in lilburn off of arcado i think
  44. liltoua
    liltoua Member
    Thank's Yerrow! I'll check it out
  45. liltoua
    liltoua Member
    UPDATE
    So my sister decided to steal my camera for her trip to France, so now I'm camera less. The only thing I have is my GoPro camera so no nice detailed pictures. Still working on timing, I can't get it right. I might just go buy a OEM belt and be done with it. I'm tired of doing it, unless one of you guys want to come help me with it HAHA. So I just stopped working on my motor for now and went to work on everything else.
    I dropped the old crossmember and threw in the new Turbo one in today. Looks like I'm gonna have to shim my control arms to make it fit. I herd people pushing out the old bushings and replacing it with new WRX bushings and it fit the crossmember just fine(without shimming). I was also thinking of upgrading them to the JDM aluminum ones while I'm at it, but who knows if I will have the funds for those right now.
    Also starting the interior breakdown. Unfortunately the wiring is very labor intensive. I pretty much have to tear everything out from under the dash and replace it with the new merged harness. The harness isn't finished yet, running into some random "don't know where this wire connects too" problems, but it doesn't matter because I'm still waiting on parts. Just pretty much tore down the whole interior and took out the dash. The heater core is next and then pulling out the old harness. I was smart and bought another set of wiring harness so that I could drive my car while it was being merged, but now that my car is down, doesn't matter HAHA.
  46. liltoua
    liltoua Member
    Got some parts in so just a small update. Nothing mechanical really. Still trying to get this damn Gates timing belt on so gonna get off work early tomorrow and work on that some more. Just got the Grimmspeed crosspipe, grimspeed EBCS and some injectors. Still need an exhaust and some random stuff, but for the most part this thing is about ready to be dropped in.
  47. SANDERS
    SANDERS Member
    Very nice sir!
  48. liltoua
    liltoua Member
    Alright so after doing some research and LOTS of re-timing, I'm just going to stick with what I have it timed to now. It's slightly off on driver side at TDC. I need to get more conformation from either a master tech or someone really knowledgeable. I've been reading here
    http://forums.nasioc.com/forums/showthread.php?t=1893380
    and
    http://forums.nasioc.com/forums/showthread.php?t=2077134
    and they say that it's perfectly normal for timing to be off by half a tooth on a brand new belt that hasn't been stretched. I've gotten 2 other mechanics to help me and this is the best we can do HAHA. It's off by half a tooth EVERY time we time it. We used both the marks provided on the belt itself and manually counting the teeth. I'm still super paranoid about it, but I need to ask around to Subaru techs who have actually encountered this problem.
  49. Cool_____
    It'll run fine but will be down on power by a good bit. On my car when I had the Gates off half a tooth we couldn't get my car to make more than 360hp on pump gas. I took car home and installed OEM belt which was DEAD on perfect. Took care back to dyno and a few super minor adjustments and no extra boost made 400 hp. That half tooth is enough to crack a valve open and screw up the powerband.
  50. liltoua
    liltoua Member
    Ouch! That's not what I want to hear HAHA. I still have a ton of stuff to buy for my swap and this OEM timing belt is going to have to find a way into my budget. If anyone has a hook up on Subaru OEM parts let me know. The cheapest I found so far is $120. I guess it would make sense to swap out the belt if it makes that much of a difference and will save my motor in the long run. That being said...who wants to buy a brand new Gates Timing belt HAHA
