My new brighton
Discussion in 'Member Journals & Project Build Stories' started by Doug@DBW Motorsports, Jul 11, 2006.
  1. Jake
    the guys at GSC are awesome. i've known Leh for a while. he's a badass behind the wheel.
    love the car, keep up the good work guys
  2. Cool_____
    Whoa! Not only is the 70hp gain crazy but the flattened tq curve is sick!
    Congrats Doug! What EM is on this car?
  3. Doug@DBW Motorsports
    TIME FOR AN UPDATE
    Here is a link to one of the dyno runs done at Cobb Tuning's facility in Salt Lake. The Car made 530hp 500tq, on a very conservative Mustang dyno. Oh and we were also 4600ft elevation. Boost would peak 26psi and then taper to 23psi at redline. FWIW this is probably about equivalent to 575hp on my dyno.
    Right Click Save-as
    http://www.autoelot.com/personal/red...os/TSDyno7.mpg
  4. 5spdfrk
    5spdfrk Active Member
    That's some nice power and curve. You should offer up rides at the next dyno day or something, because I would love to know what that kinda of power feels like.
    Keep it up guys!
  5. Doug@DBW Motorsports
  6. Cool_____
    I so love Lucy!
    That turbo sounds wicked. Doug do you like the standard 35r better than the HTA35r? I heard you were sorta disappointed in it.
  7. Doug@DBW Motorsports
  8. oneiguy
    oneiguy Active Member
    Sounds sweet. Nice numbers
  9. FACE
    That is one sexy intake manifold :naughty:
  10. Doug@DBW Motorsports
  11. ScoobyMike
    ScoobyMike OG Mod
    Nice Pics!!!
  12. kingwrex
    kingwrex Supporting Member
    Very Nice Guys.
  13. Bolderer
    Bolderer Member
    This thread is absolutely top-notch! I love the before and after.
    See you guys this week for a tune!
  14. Superdude
    Superdude Active Member
    can i ask a dumb question? good. why do they put the graphics backward on one side of a car. everyone seems to do it. well a lot of drifters do anyway.
  15. Cool_____
    It's a old JDM trend.
  16. Doug@DBW Motorsports
    used to be done so when the car was photographed the graphics would match up no matter what side the pic was taken
  17. Doug@DBW Motorsports
    UPDATE!!!
    http://forums.nasioc.com/forums/showthread.php?t=1670600
    http://forums.nasioc.com/forums/showthread.php?t=1670601
    After dominating the 2008 Time Attack season we should have probably left good enough alone. But as I am sure some have followed Redline has relaxed the unlimited class rules. Allowing for more radical modifications and changes to be made. Excited about the new rules in effect, we have decided to start building a new Shell and then swap over most of the existing drivetrain and suspension. This would make a for a fast and very cost effective build as I would only be out the costs for material and a Shell (big thanks to Slowwrx).
    Like all of TopSpeed's builds we are open and willing to share everything with the public. No smoke and mirrors here or topsecrete info. Just kick ass builds and Wins. So if there are any questions feel free to ask and we will do our best to answer them.
    Our initial plans were to take all the information we had learned from the past two seasons and build what we feel is the ultimate Time Attack car. With our end goal to have a lighter, stiffer and better balanced car. After much brainstorming we came up the following changes that need to be made.
    Lower roof (lower CoG and less frontal area)
    Lower the ride height (lower CoG)
    Move radiator to rear (weight distribution)
    Front mount turbo (weight distribution)
    New Cage Design (Stiffer less weight)
    Seam Welding (chassis stiffness)
    Adj Suspension Pickup points (better geometry)
    That is the small list of major changes we will be making. Ofcourse there will also be a ton of smaller changes, but those will not make as huge a difference.
    The current Shell weights 430lbs. I have removed excess metal from key areas that will be strenthened by the cage. Also from the pictures you can see how much I have removed from the roof (2.5"). Next up is to cut and tub the wheel wells to allow tire clearance with the car sitting so low. Then its media blasted, seam welded, and caged.
    Check back here as I plan on updating this thread with new build pictures. This build should go quick as we are scheduled for track testing in 8wks.
    Enjoy,
    Douglas Wilks
    TopSpeed Inc.
  18. slowwrx
    Like I said when I was there...fucking awesome
    Glad she is being put to good use
  19. Sparta
    damn nice. makes me want to get a shell and swap mydrivetrain over lol
  20. Cool_____
    This is again going to be SO AWESOME. So what gonna happen to the original Lucy? Using her for anything?
  21. nicad
    could you provide a little more info on seam welding the chassis? maybe some pictures and examples?
    always intrigued me, since I'm a hobbyist TIG welder
  22. Cool_____
    Basically you find all the seams where the sheet metal is joined and clean them out.....they are full of sealant and weatherproofing and such. You take something flat and metal and clean it out. Then you basically weld that seam together. There's more involved but that is the gist of it and will let Doug elaborate on that.
    Very tedious job but it makes the car much more stable and stiff.
  23. BKiller
    BKiller Active Member
    Oh. I am now subscribed to this thread!
    Could you just set up some bleachers in the shop so we could hang out and watch??
  24. Doug@DBW Motorsports
    1/9/09 - update
    Finished up on the front drivers tub along with doing some cleaning of the engine bay. Just got tired of looking at all the mess so we wheeled the car outside on the dolly's for a quick washing. Along with the wheel tube I have removed some more metal that is in areas not needed in various areas.
    Here some pics,
  25. Doug@DBW Motorsports
    1/9/09 - update
    Here some pics,
  26. Cool_____
    Doug what's gonna happen to Lucy ver 1.0? You going to ditch her shell?
  27. nicad
    what machine are you using to do the welding? I'm assuming it is AC TIG. miller?
  28. Cool_____
    I think you are right. You can see it here [​IMG]
  29. nicad
    yep! my bad. good eye
  30. slowwrx
    I think he is keeping Lucy 1 until this chassis has proven to work well
  31. mmtasty
    mmtasty Active Member
    FYI: I'm scheduled for a SS tune at 9AM Monday, and I'm going to annoy the ever living shit out of you guys climbing around the shop in all these cool projects while Scott tunes my Forester... Sorry. It's just the way it goes, being the coolest shop around and all... ;)
  32. mmtasty
    Oh, and I'm currently unemployed, so if you need a slave to grind, sand, and strip let me know. I'm down!
  33. XanRules
    XanRules Active Member
    I already unofficially applied :hs:
  34. Doug@DBW Motorsports
    New car has been renamed... it only seams fiting. Lucy will be retired for LOKI
  35. slowwrx
    Perfect
  36. Doug@DBW Motorsports
    Got bored last night so I decide to play around on forza a bit. These are no where the quality that some forza painters can do. But It gives me an idea of a what direction I may want to take.
    First in white
    Then the same but a candy red
    Look what else I get to play with in forza.. big thanks to AG-Tuning for getting it done.
  37. undrgrndrdr15
    undrgrndrdr15 Active Member
    i like the candy red but through some yellow wheels to offset it!
  38. MrCoffeeATL
    MrCoffeeATL Member
    +1 second for hitting the cone in picture 4 :p
    Looks good. I like the white better though :wiggle:
  39. Cool_____
    White FTW!
  40. Bug-Rex
    Bug-Rex Active Member
    How do you do that to your cars on forza? Ive been trying to do that for years but cant figure out how to put all those graphics on and such...
  41. integroid
    White FTW.....
  42. BKiller
    So do we get no more updates on this???
