Raw Fuel Smell
Discussion in 'Modifications & DIY how-to' started by Matto357, Jan 29, 2014.
  1. Matto357
    Went and fired the car up this afternoon, smelled very strongly of raw fuel coming through the ac system. Shut it down and it smells like raw fuel localized to the passenger side bank of injectors. Haven't pulled it apart to figure out what it might be yet. Any ideas? Maybe a cracked O-Ring?
  2. Trancetto
    Could it be the cold cramping up fuel lines... Issue that early wrx had.
  3. Matto357
    So just let it warm up?
  4. integroid
  5. b reel
    could be a vacuum line on the evap crap
  6. Matto357
    I searched already, everything mentioned earlier models and not 06's.
  7. Matto357
    Would that create the smell in the engine bay? Was very localized to the passenger side injector bank. Didn't smell anything near the charcoal canister in the back.
  8. b reel
    passenger side intake manifold beside inlet. the evap solenoid is located there and ties into the manifold, fuel rail vent line and turbo inlet. there is a blue plastic tee and the lines running off it are usually hardened from heat cycles and age. might be the source of the odor
  9. b reel
    or it could be from the flex lines in the stock fuel rails
    doesn't matter the model year, they all have a tendency to do it.
