RSutton's 2011 SSM WRX Hatch Progress
Discussion in 'Member Journals & Project Build Stories' started by rsutton1223, May 11, 2011.
  1. rsutton1223
    And so it begins...
  2. rsutton1223
    Had some fun yesterday...
  3. rsutton1223
    More parts are in...things are about to get crazy.
  4. wagunz_pwn
    He's going all pachoo-pachoo on us. First the ricer rev video and now this...great.
  5. rsutton1223
    It's recirculating!! Not a BOV...
  6. CelticPride
    CelticPride Banned
    Noob.....
  7. wagunz_pwn
  8. rsutton1223
    It was a beautiful night for a drive...
  9. driveclimbslide
    driveclimbslide New Member
    I like your photography! Keep it up.
  10. rsutton1223
  11. CelticPride
    CelticPride Banned
    When's tune day?
  12. rsutton1223
    Doug is going to be out of town for 2 weeks with One Lap so I am going to put the parts on, put on a super conservative tune and then let him work his magic when he gets back. So the final tune won't be for another couple of weeks.
  13. J_P
    very interested in your impressions of this turbo vs stock
  14. Jake
    this is the dom 1.5xt yes? excited to see numbers on the newer WRX's i know King is going with this too
  15. rsutton1223
    that's the one! King's is already in...he is just running on a break-in tune right now.
  16. rsutton1223
    The good news...
    I got in a set of prototype rear brackets in from KNS Brakes so I can finish my Brembo brake project.
    Even better news...they look great installed!
    Now the bad news...
    Everything is absolutely perfect...until I bolt on the wheels. Everything completely locks up as soon as I torque down the lug nuts. Apparently...the difference between 07 and 08 STI rotors is a slight hub depth difference. When you bolt up 07 STI rotors to my car, the rotor gets pressed against the parking brake backing plate.
    New slotted rotors on the way from KNS and the original brakes are back on the car until later this week.
  17. Matt
  18. liltoua
    liltoua Member
    Looks soo good =)
  19. rsutton1223
    Rears are complete. Big thanks to Ken at KNS brakes for making the brackets, supplying the rear rotors and putting up with my constant asking about the brackets progress.
    The brackets work PERFECTLY. A little bit of grinding off the knuckle and they bolt right up.
    My original teaser picture showed drilled rotors. For one...those didn't work because there is a depth difference in the e-brake between 07-08 which makes the rotors completely lock up when you torque down the wheel. This was ok with me as I wanted to switch to slotted from drilled anyway, so Ken sent over a set of 08+ STI DBA 4000 STI rotors drilled for 5x100. Everything mounted up nicely...
    Once the everything was bled, caliper was waxed and the wheel was torqued down...I went for a drive and everything performed flawlessly. The car is insanely dirty from a lot of driving this week...but here is how they look behind my Works.
    Now I just have to get slotted rings for my fronts to get rid of the drilled rotors I hate and everything will be matched up. It's nice to finally have the rears on.
    The fronts for reference...
  20. whtwrx11
    whtwrx11 Member
    Looking good!
  21. rsutton1223
    Played at AllPro Subaru in Alpharetta, GA today...
  22. All Pro FTW
  23. rsutton1223
    Parts from TS and the mack daddy tune will be rocked by Doug.
  24. :p I'm just giving you crap!
  25. rsutton1223
    Don't you know I am a super sensitive baby online? :rofl:
  26. CelticPride
    CelticPride Banned
    380hp on 93 octane here we come. Hopefully we see some e85 too!
  27. rsutton1223
    Low boost map until the EBCS is installed. Only hitting around 16 pounds right now. Tune by Doug at TopSpeed Motorsports. It really is impressive to see how Doug can tweak a car and make small adjustments to get a desired result. The guy knows Subaru's. We will be doing the final map on the car once the EBCS comes in, but the car already feels SUPER smooth.
  28. RSConvert
    Very nice Robb.
  29. Glad you got it all tuned up bro ;)
  30. resynch
    resynch Supporting Member
    I saw this at AllPRo Subaru last week (Great guys btw) and I would like to be just like you when I grow up...lol. Nice work and beautiful car.
  31. J_P
    I bet it's a totally different car now. Good work sir. I want to know what you think of that turbo in the mtns. How is spool compared to stock?
  32. rsutton1223
    Spools just like stock. That is what is so great about the 1.5. It makes more power than a 20g and spools quicker.
    Wideband is in.
  33. rsutton1223
  34. CelticPride
    CelticPride Banned
    So how is the custom Sparco coming along?
  35. Matt
    I'm looking at it right now.
  36. rsutton1223
    :squint:
  37. CelticPride
    CelticPride Banned
    I just noticed the missing foglight. Intake?
  38. rsutton1223
    Yep. Keeping intake temps down. I need to figure out something to block water though.
  39. CelticPride
    CelticPride Banned
    Is the pipe directly connected to the intake? Reason I'm asking is I built something simliar on mine and it caused my car to stall if you threw it in neutral while coasting.
  40. rsutton1223
    No tube. Just bring air into the chamber where the cone is.
  41. CelticPride
    CelticPride Banned
    Cool. That's what mine did but I also had it such that it forced air through the filter at speed. Worked like a freaking charm in keeping the IAT sensor cool and happy but again coming up to a stop light and throwing car in neutral to coast there = sputter. MAF was picking up airflow but the throttle body was closed = flooding cylinders.....LOL.
    Doug couldn't figure it out, Scott couldn't figure it out. Ol WJM figured it out in 10 mins and I had driven to Jacksonville to just turn around and go home....le' sigh.
  42. rsutton1223
    Today was a good day to say the least. Final 93 pump tune is on the car and it is pretty strong. Doug at TopSpeed Motorsports did work.
  43. CelticPride
    CelticPride Banned
    Looking good man. Whens e85 tune?
  44. rsutton1223
    I'll do that when the block is built.
  45. CelticPride
    CelticPride Banned
    You are making almost as much power as a 'built' block I heard of. You should be very happy.
  46. WRXbryanATL
    WRXbryanATL Member
    More power than my "built" ss1 block.
  47. CelticPride
    CelticPride Banned
    And before anyone says anything......built motors don't make more power if all elements are the same (i.e. forged pistons only). They just are able to take more abuse.
    But who builds a motor and doesn't change compression, add cams, etc? :rofl:
  48. slowwrx
    Should be able to pick up some torque on spool up with the right cams and some head work. Should also be able to carry the power out to 7250-7500.
    From what I've seen so far with the DOM 1.5 there is very little loss spool wise but there are major gains to be had up top with a front mount.
    I like the simplicity of the Top Mount but the Front Mount is clearly superior at this power level.
  49. slowwrx
    Most people....lol
  50. CelticPride
    CelticPride Banned
    True....sad.
